Drag slick question? Sorry if wrong place.
Old Feb 19, 2009 | 06:11 PM
fullyboostin's Avatar
Default Drag slick question? Sorry if wrong place.
What is the biggest slick and rim I can run on my stock integra wheel studs?
Old Feb 19, 2009 | 06:21 PM
Jas9848's Avatar
Default Re: Drag slick question? Sorry if wrong place.
lensos will fit on stock studs. most others require extended studs.
Old Feb 19, 2009 | 06:27 PM
Lensos are pretty reasonably priced too right?
Old Feb 19, 2009 | 07:47 PM
turboaap's Avatar
if you are going to run slicks i would put the extended studs in!!!
Old Feb 19, 2009 | 08:01 PM
ExospeedAMcrx's Avatar
Our Exospeed/Lenso VPD wheels can use stock studs. The lug design is an acorn style so you can use regular lug nuts.
Even though its not necessary to use extended wheel studs to make it work, track rules usually require extended wheel studs on any car using slicks.
Any other questions, feel free to PM or contact us.
As far as biggest slick, that shouldnt be the question you should be asking. Slick size all depends on your setup. HP level, gearing, etc.
Then go from there.
these are 24.5x9x13 on our VPD wheels
Old Feb 19, 2009 | 11:05 PM
Thanks for the input and my car makes 315 whp and is a turbo b16 in an integra by racing season it should be closer to 350-370 any suggestions on tire size?
Old Feb 19, 2009 | 11:15 PM
You should be fine with a 23x8x13 MH slick.
Old Feb 20, 2009 | 12:00 AM
ACTION JACTION's Avatar
Hey Exospeed, do you guys carry a 16" slick? PM if you do. Thanks.
Old Feb 20, 2009 | 08:48 AM
Cool thanks for the input.
Old Feb 20, 2009 | 01:38 PM
Boosted_Coupe's Avatar
I have the exact same slick/rim setup, and was wondering if you run a spacer at all? I'm a little worried about the slicks being too wide.
Old Feb 20, 2009 | 01:46 PM
Its not our car. Its one of the SFWD racers here in SoCal, TB Motorworks in San Diego, CA. I dont know if he runs a spacer or not. We've sold that setup at least a hundred times and i'm sure there are another couple hundred that have ran that setup as well.
In my opinion, I would get a spacer. The 24.5x9x13 M/T is pretty wide and may rub the inside fender if turned too much. A 1/4" spacer wouldnt hurt.
Old Feb 20, 2009 | 02:14 PM
Thanks for the fast response. Also, i'm only making 360whp and went 11.60 with a gsr tranny and 23x8x13 slicks. I'm hoping to make 400+ this year, are these slicks overkill or should i stick with 23x8x13?
Old Feb 20, 2009 | 02:16 PM
1junkycivic's Avatar
I run spacer on mine1/4
Old Feb 20, 2009 | 02:27 PM
It looks like you cut your fender's, was this done just as a pre-caution, or did you have rubbing issue's?
Old Feb 20, 2009 | 02:43 PM
Not cut thats from slicks hitting during hard turning.
Old Feb 20, 2009 | 02:47 PM
Damn I'm very nervous to run these 24.5x9x13 MT on my car. Maybe I'll just stick with the 23x8x13 MH and rev to 9k lol
Old Feb 20, 2009 | 02:54 PM
Dont worry my front end alignment probably has to do with it rubbing its been done with my eyeball.LOL
Old Feb 20, 2009 | 03:05 PM
I wouldnt go 24.5 at mid 300s. You have to consider that your PEAK HP maybe at 360 but most of your useable HP is most likely in the low 300s. 24.5 will be overkill at that hp.
DC206R
Apr 28, 2009 06:52 PM
Running925
May 13, 2008 12:50 PM
Topdawgg
Aug 3, 2007 07:10 PM
2k.civic.si
Feb 22, 2005 07:49 PM
EKFerioHawaii
Oct 2, 2002 02:08 PM
