Purpose of extended studs?
Old Apr 27, 2009 | 08:52 AM
DC206R's Avatar
Default Purpose of extended studs?
i have no idea what they are for but i see people using them with aftermarket wheels. I'm going to pick up some wheels that are 16X7 or maybe 8. i relaly have no idea if i need extended studs or not.
Are extended lugs only supposed to be used on extended studs?
Old Apr 27, 2009 | 12:20 PM
TunerN00b's Avatar
Default Re: Purpose of extended studs?
Extended studs are needed when using spacers between the hub and wheel, to reduce the offset, or for unusually thick wheels (thick in the mounting area).
Then you need either extended lugs or open ended lugs, to go with the extended studs.
Using extended lugs on standard studs is for cosmetics only, and is fine as long as the lug has adequate thread engagement.
Old Apr 28, 2009 | 12:57 PM
ozzyman's Avatar
Extended studs are a requirement for some track racing and drag racing. Also if I'm not mistaken they are required when running slicks at the track.
Old Apr 28, 2009 | 06:52 PM
rated_r1's Avatar
From what I know you stand correct and we need them on our drag hatch. I also have them on my DC2 but that is only for cosmetic purposes. Having the actull studs stick out past the wheel a little with opened lug's looks nice to me. But that's just me.
agol
May 24, 2011 06:15 PM
Topdawgg
Aug 3, 2007 07:10 PM
dunkd
Jul 19, 2005 01:51 PM
HARI.
Jul 9, 2004 09:00 AM
TurboLude97
Jan 14, 2003 09:43 PM
