Help! Another blown oil pump
Old Feb 18, 2009 | 10:08 PM
wickedplastikman's Avatar
Icon6 Help! Another blown oil pump
this is the 2nd oil pump that went bad on me on a stock gsr. the car was normally driven. the 1st pump wore out and showed low oil pressure. i changed it out and everything seemed fine except it started throwing the vtec oil pressure code. took it to the dealer after running out of ideas and they said it was showing low oil pressure again. there was never and gold flakes in the oil or in the pan. never had any knocking either.
could there be something wrong with the engine making the oil pumps go bad? or do i just have **** luck with my oil pumps?
Old Feb 19, 2009 | 12:04 AM
delbert's Avatar
Default Re: Help! Another blown oil pump
bump for the oil pump problem ha!
Old Feb 19, 2009 | 01:47 AM
blkb18's Avatar
Anything done to the motor? Any previous internal work or aftermarket crank pulley? Do you have the old oil pump? If so I would take it appart and see how it wore, you may have improper thrust clearance in the crank, alowing it too much movement which can destroy a pump.
Old Feb 19, 2009 | 09:13 AM
as far as i know the motor has always been stock. stock crank pulley also. how can i check for thrust clearance in the crank?
Old Feb 19, 2009 | 12:20 PM
ttt
Old Feb 19, 2009 | 10:33 PM
Originally Posted by wickedplastikman
ttt
no more info?
Old Feb 20, 2009 | 08:31 AM
help
Old Feb 20, 2009 | 09:02 AM
mouab18c1's Avatar
if you got a CEL for vtec oil pressure..the sensor could of took a dump on you....try changing the sensor first to see if the code comes back
Old Feb 20, 2009 | 10:49 AM
i tried that already. changed the pressure switch first. then i changed the whole thing. still didnt work.
Old Feb 20, 2009 | 02:40 PM
1Point8DC2's Avatar
you need to verify actual oil pressure to see if you actually have a pressure issue. the helms manual shows how to check runout and how to check the crank journal that slides inside the pump.
sleepyhatch00
Sep 2, 2005 01:35 PM
NVturbo
Nov 20, 2004 03:48 PM
dbang003
Oct 21, 2004 05:31 PM
MayhemSi
Oct 7, 2003 02:24 PM
PROFILES2000
Feb 25, 2002 01:17 PM
