broken oil pump ?
Old Oct 19, 2004 | 12:07 PM
dbang003's Avatar
Default broken oil pump ?
earlier this year i broke my oil pump on my boosted gsr motor....motor is bone stock internally...i replaced it with an oil pump from honda and i think it broke again the other night...have 0 oil pressure but engine runs fine...i'll find out for sure once i get a chance to look it over...
i was just wondering if my setup is prone to breaking the oil pump because i am using the ctr n1 crank pulley...i can see it breaking once because the motor does have a lot of miles on it, but for it to break again only like 4 months later and hardly any miles on the car...i would say i haven't even put 1000 miles on it...thanx for any info...peaces
drew
Old Oct 19, 2004 | 12:28 PM
BoostR41's Avatar
Default Re: broken oil pump ? (dbang003)
most cars I have seen with blown oil pumps have aftermarket crank pulley's....don't even start the car if you have no oil presure you will spin the bearings
Old Oct 19, 2004 | 12:30 PM
m R g S r's Avatar
Make sure the gauge is working, and if it is, leave that motor off! What RPM are you spinning the motor to?
Old Oct 19, 2004 | 01:04 PM
93LSivic's Avatar
Could be that C1 pulley. It is not a dampener so it can be damaging the oil pump.
Or the mains could have moved around a bit. Also possibly loose flywheel bolts.
Old Oct 19, 2004 | 02:57 PM
dbang003's Avatar
Default Re: broken oil pump ? (93LSivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Make sure the gauge is working, and if it is, leave that motor off! What RPM are you spinning the motor to?</TD></TR></TABLE>
i'm gonna pop off the oil feed line to the turbo and turn the motor over to see if i get anything...revving to 8100, but only ever at the track...on the street i usually get to about 7500 or so...it stuttered in 4th gear at like 5.5-6k...that's when i looked at the gauge and saw 0 oil psi...so i shut it down...might just go back to the stock pulley if it is the pump that broke again...thanx for the help...
Old Oct 19, 2004 | 03:32 PM
Jared's Avatar
go ahead and get a fluidamper or an ATi.
Old Oct 19, 2004 | 03:54 PM
pngfolife's Avatar
CTR pulley on boosted cars = NO NO!!! The CTR pulley doesn't have enough mass to dampen vibration. You definately shattered your oil pump gear. Don't start the car!!! Pull your cams and I bet you will find your cam bearing journals scored to all hell. Next time, go with an ITR pulley.
Old Oct 19, 2004 | 05:49 PM
DaX's Avatar
DaX
Loved
Community Favorite
Resonance, harmonics, vibrations. These are what killed your oil pump...twice. You should have your crank balanced, and possibly use a Fluidampur.
Old Oct 19, 2004 | 07:04 PM
m R g S r's Avatar
Default Re: broken oil pump ? (Jared)
From what I've read, the ATI pulley isn't really a dampner. The fluidamper is the only one which really takes care of the task, that's What I'm gonna use on my built motor.
Old Oct 21, 2004 | 05:31 PM
dbang003's Avatar
Default Re: broken oil pump ? (m R g S r)
i figureed it was the ctr pulley...i kinda thought that when the first one broke, but the motor has a lot of miles on it...guess it's time to upgrade to a fluidampr...anyone know of anyplaces that have good prices on em...i've seen em for around $340ish...thanx
drew
wickedplastikman
Feb 20, 2009 02:40 PM
sleepyhatch00
Sep 2, 2005 01:35 PM
NVturbo
Nov 20, 2004 03:48 PM
MayhemSi
Oct 7, 2003 02:24 PM
PROFILES2000
Feb 25, 2002 01:17 PM
