Anyone blown up an oil pump?
Old Oct 7, 2003 | 09:49 AM
MayhemSi's Avatar
Default Anyone blown up an oil pump?
Anyone blown an oil pump up while driving? What happened when that happened if you did? I was cruising last night and all of a suddent my oil light came on, there was a little clatter under the hood, and the motor died I'm tryin to get some ideas....
Old Oct 7, 2003 | 10:15 AM
b20turboic's Avatar
Default Re: Anyone blown up an oil pump? (MayhemSi)
my buddy has blown quite a few and swears its his UR race pully
Old Oct 7, 2003 | 12:05 PM
MayhemSi's Avatar
Default Re: Anyone blown up an oil pump? (b20turboic)
Hrmm.. thats odd.. I have an underdrive pulley as well.. I hope its just the oil pump and not a broken rod or something...
Old Oct 7, 2003 | 12:29 PM
b20turboic's Avatar
check for metal shavings in oil pan/filter if shaving are found you in a heap of poopie
Old Oct 7, 2003 | 12:34 PM
johnisenglish's Avatar
Mine went out last week
Old Oct 7, 2003 | 12:39 PM
spooler's Avatar
UR pulleys kill oil pumps. Lack of a harmonic balancer creates to much play/vibration in the crank and ends it all. UR pulleys are not worth having.
On the topic of oil pumps. Has anyone tried a Toga oil pump?
http://www.importperformancepa....html
Old Oct 7, 2003 | 12:41 PM
earl's Avatar
Default Re: (spooler)
No harmonic balance = death to oil pumps
I assume you checked to make sure you did not break a timing belt. You could get the symptoms from that.
Old Oct 7, 2003 | 01:31 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (earl)
vibrations kills oil pumps and bearings.
art
Old Oct 7, 2003 | 01:44 PM
speedworks's Avatar
Default Re: (Arturbo)
i blew 3 oil pumps before realizing it was that stupid ur crank pulley. took it off and have not popped one in two years.
Old Oct 7, 2003 | 02:09 PM
B18C GSR CIVIC's Avatar
Default Re: (speedworks)
U/R CRANK PULLY IS TRASH FOR ANY ENGINE MAKING CLOSE TO 300WHP AND MORE
They swore with the pro drive oil gears I wouldnt have a issue. Well when I called then back with over 5000$ in damage they said well its your fault. I took the PULLY OFF, Smashed it into pieces and that was the first time I smiled in awhile.
Now making close to 500 and ZERO issues! STOCK CRANK PULLY
Old Oct 7, 2003 | 02:24 PM
Jefnes's Avatar
NO ****..... This makes perfect sense.
I went through 2 pumps already. Just got the motor back, tuning in progress.
I heard the 'plink', checked the guage, zero pressure, shut it down. Saved the motor, no spun bearings.
Yep I have some sort of LW pulley. Still do.
Time to go back to stock pulley.
Jeffrey Atwood
somick
Aug 15, 2017 08:14 AM
wickedplastikman
Feb 20, 2009 02:40 PM
sleepyhatch00
Sep 2, 2005 01:35 PM
eag36
Mar 30, 2005 05:40 PM
