Used wrong Oil in my Civic
The higher number means the oil is thicker "higher viscosity"
If you are really worried about it you could open the drain plug and drain it out, then put the right stuff in. But it will not hurt your engine. Might feel a little slugish on the petal thats all.
i would drain it if you dont want to continue to run 10w-40 your really not supposed to go back down if you continue to drive that motor with that thickness of oil.
these things will occur because of thicker weight:
more engine wear
less gas mileage
engine works harder
its very minimal but your call if you want to do a drain and fill.
more engine wear
less gas mileage
engine works harder
OP, listen to someone who knows something about oil. 10W-40 technically will be fine to use. Hell, you can use ANY kind of oil you want, oil is oil and there is just different aspects of different oils for different applications. First of, the oil IS NOT that thick. If anyone knew what 10W-40 stood for then they would tell you the 10 stands for the thickness, the W meaning it is a winter oil or just all season, and lastly the 40 standing for how much heat the oil can handle. Therefore, 10W-30 is the EXACT same oil besides the fact that the 40 weight holds more heat, and could possibility a diesel rated oil (like 15W-40 or something, since most diesel engines require a higher heat holding oil) That is why in some racing application they use a straight 40 weight oil or something since it does not need to be a winter oil. And lots of people use 10W-30 in their car! Well mostly old farmers since it's usually what they swear by. Point is you will be fine using 10W-40 if you cannot afford 5W-30 or something or don't wanna drain it since it's new, but if you can I myself would just put 5W-30 in if you don't mind buying new stuff
For a motor that calls for 5w-30 and know your going up to 10w-40. Yea there is something wrong with that it will put strain on the motor. Secondly if your regularly putting 10w-40 in your motor there must be a problem with the tapping there is no need for 10w-40 . You can always go one step ahead of what your oil specs say because after time the motor will eventually become out of spec's thus running a thicker oil such as 10w-30.
yeah, I think it would be okay, I regularly use 10w-30 since its always cold down here, and I am getting up there in mileage. As long as there is no permnament motor damage, I will definatly go back to 10w-30 the next cycle.
That's not right, you should use thicker oil in HOT temperatures, not cold. Thicker oil is not great for cold starts..
I use to run thicker oil in the summer here as it was hot and my EF had 200+ miles on it. It helped to not burn as much oil. Just don't go insanely thick and it will be fine.
OH MY GOD YOUR GONNA BLOW IT UP!!!! AHHHH NOO!!! just kidding. The number plus the letter w stands for its weight below freezing in the winter. 10w30 would have an effect on your car if it was cold out because its thicker at lower temperatures, thus making it harder to move through the engine. Higher oil pressure, harder to flow= not as good engine lubrication. If you live in a warm area then its chill, but its its super cold where you live then i'd probably change it
jdm.boi408
Feb 8, 2011 07:24 AM
EG-SIXV-TEC
Jun 12, 2010 10:47 PM
EK45VTi
29
Apr 30, 2004 07:37 AM
