D16Z6 timing lines??
Old Feb 17, 2009 | 02:51 PM
supermario680's Avatar
Default D16Z6 timing lines??
my book doesn't say where the notches on the block should line up on the crank pulley,
it says there are 3 lines, (red dot) and one line (white dot) farther up,
on a d16z6 where should they line up on the crank, red dot?? 1st 2nd or 3rd or closer to the white dot? ?
Old Feb 17, 2009 | 04:32 PM
p73hatch21's Avatar
Default Re: D16Z6 timing lines??
just take your sparkplugs out and stick a long skinny screw drive in num#1 cylinder and get the piston top dead center and look at the red and white makers. what ever one is closer is for the win!! but i have never not seen a timing maker on the oil pump. but make sure the up arrow is towards up on the camshaft!! so you dont mess a valve up!
Old Feb 17, 2009 | 04:37 PM
turboedsohc89's Avatar
well if your looking for DTC the piston closest to the Tbelt is always #1cylinder and just he said up there but i use the oil dip stick . hope it helps any....
Old Feb 17, 2009 | 04:41 PM
nightscream's Avatar
you can do it his ^ way but, I always ALWAYS ever since I just started learning about hondas (about 15yrs ago) find the arrow on the timing cover look straight down on it and line it up with the RED mark and make the cam gear has the "UP" pointing straight up and your in TIME!!!!!! I never use a timing light and never, NEVER had a problem. alot will disagree but I swear it works
Old Feb 17, 2009 | 05:22 PM
p73hatch21's Avatar
yeah... its weird theres not a timing mark, i have always found one.. if not on the oilpump theres one on the timimg cover.
Old Feb 17, 2009 | 05:33 PM
Well no work was recently done and the timing cover is still on.
So idk if the arrow on the cam is pointing up or not.
I was using a timing light, since the engine is not apart.
and am wondering if the "sights" should line up with which "RED DOT" line?
the middle one?
Old Feb 17, 2009 | 05:35 PM
sorry, thats the one I was talking about. the "gun sights thingey"
Old Feb 17, 2009 | 06:06 PM
p73hatch21's Avatar
take your harmonic balancer off and there is a lil knoch on one tooth on the crank gear line that one mark on the gear with the one on the timing cover.. then your done.
Old Feb 17, 2009 | 06:55 PM
Im using a timing light, since the engine is not apart.
which "RED DOT" line? the first middle or last?
Old Feb 18, 2009 | 08:12 AM
bump?
Old Feb 18, 2009 | 05:26 PM
bump bump??
Old Feb 19, 2009 | 01:08 PM
Old Feb 19, 2009 | 11:33 PM
Didly's Avatar
If your doing your ignition timing then Im pretty sure its the middle... the farther one all by itself is for TDC (top dead center)
Here and since Im such a nice guy.. take a look at this! Your engine is at the bottom basically...
the 1st pic is kind of universal in understanding which notch it is...
http://www.autozone.com/shopping/rep...00c15280061650
Old Feb 20, 2009 | 12:06 AM
trustdestruction's Avatar
it needs to line up with the notch that's in the middle of the group of three notches. i don't remember the color.
pretty sure it's 12 degrees BTDC
Old Feb 21, 2009 | 10:18 AM
Thats what I needed to know!! thanks. btw b15d8's are at 12 btdc, the book states my d16z6 should be at 16 deg. but im sure mine is supposed to line up with the middle line. thanxs!!
Old Feb 21, 2009 | 11:52 AM
No problem. The 12 degrees BTDC I remembered must be from the D15B7 I used to have with my old Civic.
dL_EG6
Dec 16, 2012 04:36 AM
jlfrnce
Dec 10, 2009 10:12 PM
lilshady6796
21
Mar 31, 2009 09:18 PM
ef-hatchcrap
Jun 15, 2007 12:01 PM
88rexdxa6ed
Apr 24, 2004 11:51 AM
