99-00 EK9 Green ECU PLUG QUESTION
Old Feb 17, 2009 | 06:37 AM
jdmnovice-21's Avatar
Default 99-00 EK9 Green ECU PLUG QUESTION
Good morning everyone,
Just have a question regarding the green plug for the ek9 ecu.. My friend and I swapped in the B16B type R motor into a 00 EK hatch (motor only); we've installed a 2000 civic SI engine harness onto it (everything plugs in perfectly); I was told that the green plug for the ecu (pins in the plug) would need to be switched around in order to work ~ something about the cluster, fuel pump etc. Not sure; I was told the the current wires do not correspond with the JDM ECU. Is this true? Others are telling me that it's a straight plug and play..Please help answer this for me...I'm confused.. Can someone verify this for me please. Also, I'm using the Type R ecu that came with the engine. Thanks in advance!
Old Feb 17, 2009 | 12:42 PM
Default Re: 99-00 EK9 Green ECU PLUG QUESTION
any help would be greatly appreciated.....
Old Feb 17, 2009 | 04:33 PM
geebs's Avatar
The green plug that plugs from the engine harness to the underdash harness?
It shouldn't need to be modified.
Old Feb 17, 2009 | 04:45 PM
alacard's Avatar
I am pretty sure a JDM ecu will work fine. I've ran a chipped JDM p72 for a year or two without swapping any pins.
Old Feb 17, 2009 | 06:00 PM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
did you try it and it doesnt work? from readin your post it sounds like you havent tried it yet.
alacard
13
Jun 8, 2007 06:10 PM
alien
Oct 16, 2006 11:26 PM
BLKCivicPorscheStyle*
Aug 22, 2005 12:46 PM
EE_Chris
Jul 3, 2002 06:29 AM
