4K RPM Stall
Old Feb 16, 2009 | 05:11 PM
ek_sleepr's Avatar
Default 4K RPM Stall
Okay so the otherday i was on my way home and my check engine light came on so i was like WTF !? now my car wont pass 4k RPM and the check engine light goes away after a while and the tends to turn back on. I have to turn my car off at a stop 2 pass 4k. Any idea what this bugg is ? (K20A3) EP3
Old Feb 16, 2009 | 05:14 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: 4K RPM Stall
what are your mods?
Old Feb 16, 2009 | 05:16 PM
ek_sleepr's Avatar
K&N air Filter . that is all.
Old Feb 16, 2009 | 05:21 PM
eMpAtHy's Avatar
bring it to autozone or kragens/checkers to see what code you're throwing. when you go into limp mode, you can't rev over 4k.
Old Feb 16, 2009 | 05:24 PM
ek_sleepr's Avatar
Yeah some guy told me his FG had gone into Limp Mode but it went away .
Ima throw in my scanner right now and post the codes it had right now brb.
Old Feb 16, 2009 | 05:30 PM
ek_sleepr's Avatar
Ok so it gave me this code :
P1259
Manufacturer Contrl
Fuel Air Metering .
Old Feb 17, 2009 | 05:34 AM
mustclime's Avatar
check your gas cap, if its not sealing, you fuel pump can not get the right fuel pressure=limp mode. While you are at it, check your oil level, that gets to low and the motor will go into limp mode. After you find the problem, with the key off, pull the ecu fuse from the box under the hood, this will reset your ecu.
Old Feb 17, 2009 | 07:51 AM
ek_sleepr's Avatar
Thanks alot bro. ill check both today and see how things turn out . ill keep you guys posted!
Old Feb 17, 2009 | 05:44 PM
ek_sleepr's Avatar
Ummm so this is what i did to take care of my Limp Mode Status ......... Changed my oil to Mobil Clean 5000, New NGK Iridium Spark Plugs.Got a new gas cap of an RSX. Cleaned my fuel Injectors. New Oil Filter. and reseted my ECU how my freind here told me ^_^
RUNS GREAT ! NO MORE 4K STALLING and i-VTEC kickis in HARD YO !
lol
Thanks alot guys .
Old Feb 18, 2009 | 05:14 AM
josh's ep3's Avatar
Function > Form
Damn, you got a EP right? I'm glad you got your car figured out, but tell me this, when does your vtec kick in hard? Or was that a joke seeing how you have an A3 and all...
Old Feb 18, 2009 | 07:19 AM
mustclime's Avatar
Yea, the a3 vtec is a monster.........
Old Feb 18, 2009 | 07:38 AM
josh's ep3's Avatar
Function > Form
Oh I know dude...
Old Feb 18, 2009 | 08:12 AM
Blackcatn2o's Avatar
Why do you guys make fun of your cars?
Old Feb 18, 2009 | 08:37 AM
mustclime's Avatar
The I-VTEC in the k20a3 is not much to brag about. You only have the extra cam lobes on the intake side and it "kicks in " at 2200 rpm....you see, the k20a3 runs on one intake valve per cyclinder till 2200 rpm and then the vtec starts using the other intake valve.....so if you drive a k20a3, vtec is kinda a bad joke.
Old Feb 18, 2009 | 08:55 AM
ooooookkkkk what ever floats your boat!
Old Feb 18, 2009 | 10:04 AM
ek_sleepr's Avatar
Yeah dude i know i was exagerating ..... you swear my a3 vtec kicks in like that lol
Old Feb 19, 2009 | 10:37 AM
burnout8488's Avatar
I would think that resetting the ECU probably got rid of the limp mode, and would have even before you did all of the maintenance items.
P1259 is "VTEC System Malfunction." (According to a google search) I don't think the gas cap helped you at all.
Either way, all of the maintenance you did probably made it run better.
Old Feb 19, 2009 | 11:19 AM
mustclime's Avatar
that code comes up a lot when you are a qt low on oil....20wt oil sucks.
Old Feb 20, 2009 | 10:38 AM
stickyicky's Avatar
lol
Thanks alot guys .
p1259 is a vtec malfunction...meaning your low on oil or something else more serious is wrong with the vtec system.
Changing your oil would do the trick, but you have to think why you were low on oil???
nsxter
May 12, 2010 04:24 PM
jikespingleton
Jul 24, 2006 10:10 AM
JThrasher79
Dec 29, 2005 02:28 AM
Carbon_Lude98
Aug 15, 2004 07:28 PM
kamdog
Jan 5, 2003 05:48 PM
