Suspension & Brakes Theory, alignment, spring rates....
92-95 civic brake booster question
Old Feb 16, 2009 | 03:41 PM
TcUiRvBiOc's Avatar
Default 92-95 civic brake booster question
i got a 94 cx and i just took front, rear and mc off of a 94 si and went to put master cylinder on and the studs on the brake booster r opposite the mc from the si, it looks like i can just rotate the booster? anyone ever done this and does it work fine? and also the fitting for the brakeline that screws into the mc is a lil smaller on the cx so can i just get a fitting that has the smaller female end and the bigger male end and put it between the line and mc or do i need to cut and reflare the line with the right fitting??
Old Feb 17, 2009 | 02:50 PM
TcUiRvBiOc's Avatar
Default Re: 92-95 civic brake booster question
anyone?
Old Feb 17, 2009 | 03:18 PM
dave181's Avatar
ur car probably didint have abs and the other 1 did or vice versa you probly just got the rong mc but if ur old 1 was bad chances r ur booster will go out soon id rather be safe then sorry and get a new booster as well and ur brake system will be way beter keep us posted
Old Feb 17, 2009 | 05:27 PM
TcUiRvBiOc's Avatar
my old mc never went out just tryin to upgrade to the right mc for rear disc.. ima just rotate the booster and get a fitting that will fit the si mc and c what happens..
Old Feb 19, 2009 | 03:13 PM
dave181's Avatar
u should get the booster that the si had i dont recomend mixing parts like that anything can happen good luck let me know how it works
fongph
Jun 28, 2006 09:16 PM
fongph
Jun 16, 2006 06:05 PM
lollypopking
Jan 16, 2005 09:51 PM
DRKSol
Sep 14, 2004 09:04 AM
ares650
26
Feb 19, 2004 10:08 PM
