Eg rear disk conversion ?
Old Feb 16, 2009 | 03:41 PM
GReddy SI's Avatar
Default Eg rear disk conversion ?
I am trying to figure out if these rear brakes came from a integra
this a pic of the rear disk conversion i am trying to figure what car they came from
do all integras come with a rear sway bar?
because the rear lca's doesnt have the hole for the sway bar
or is there a stamp somewhere on the trailing arm to id the part and to know
what car it came from . he said it has abs lines on it
rotor size 9.4
Old Feb 16, 2009 | 07:40 PM
GReddy SI's Avatar
Default Re: Eg rear disk conversion ?
bump
Old Feb 16, 2009 | 08:16 PM
speedfreek128's Avatar
i believe all civic and integra rear rotors are the same size so it shouldnt matter
Old Feb 16, 2009 | 08:18 PM
97ej6dx's Avatar
for the 4 lug rear rotors i know its cheaper to just buy used trailing arms but how bout if one wanted 5 lugs all the way around would one beable to press wheel bearings and hubs in to the existing spindles or are the spindles and trailing arms different?
Old Feb 18, 2009 | 01:26 PM
i looked on an acura parts site and the bearings are the same so the hubs should be interchangable
Old Feb 18, 2009 | 01:28 PM
from what ive seen you can convert to 5 lug by just changing hubs and rotors. the ITR caliper bolts right on with no mods
Old Feb 18, 2009 | 02:38 PM
EL Vap133's Avatar
Did they come with those LCAs originally? If so then they came off an EG that had rear disc brakes.
Old Feb 18, 2009 | 04:26 PM
Jas9848's Avatar
look like they are off of a dc chassis. any 92-00 rear brakes will bolt up.
88 EF Hatch
Mar 3, 2009 10:12 AM
Kr4nG
Oct 28, 2008 08:42 AM
soon2bdropped
Nov 22, 2007 12:44 AM
ka-nife_
Jul 26, 2005 05:00 AM
