Sandwhich Adapter
Turbo install:
I was thinking of using an oil sandwhich adapter where the filter goes. Would a regular Honda adapter work ok?
I'd still leave the stock cooler in place as well.
Thanks in advance.
Thanks in advance.
Depends on the manifold you are running. Many manifolds require the filter to be removed or leave very little room for a sandwich. I HIGHLY recommend getting a re-location kit. Most people remove the factory oil heat exchanger and replace the threaded stud thing with a shorter one from another make honda (required when remove the exchanger).
I ordered the adapter, and will run my feed from it.
mhoang7
Honda Civic (2001 - 2005)
10
Jun 9, 2008 02:11 PM
Halo
26
Jul 4, 2006 04:43 AM
