Changing the Oil Filter
Old Aug 1, 2001 | 03:12 PM
no_limit's Avatar
New User
Default Changing the Oil Filter
Hey I was wondering if anyone has a tough time changing the oil filter on your Tegs? Is it just me or is it really hard to get a good grip on that thing when youre laying underneath your car? Is there an easy way to take it out?
Old Aug 1, 2001 | 03:19 PM
Quikness's Avatar
New User
Default Re: Changing the Oil Filter (no_limit)
Buy a Honda Oil Filter Cap. The cap fits over the oil filter. It has a nut on top of it (i believe 12mm) that you can use a 12mm box wrench on it to loosen the filter.
Old Aug 1, 2001 | 03:48 PM
samagon's Avatar
Default Re: Changing the Oil Filter (Quikness)
I assume installing a lift at your house isn't an option?
it makes it easier, but it doesn't make it easy.
I don't even mess with it, I get a free wash,wax, and vacuum when I take it to the dealer to let them change the oil
Old Aug 1, 2001 | 05:47 PM
Integ90's Avatar
Use sandpaper
Old Aug 1, 2001 | 05:56 PM
brinks's Avatar
Default Re: Changing the Oil Filter (Teken)
Changing the oil has actually become pleasant for me. Gloves forthe hands and its all done in 20 minutes or so.
Old Aug 1, 2001 | 07:36 PM
Ibuprofen's Avatar
go to kragens or pep boys, they have this tool, looks kinda like a pair of plyers with big *** teeths. very easy to remove filter with this tool
Old Aug 1, 2001 | 08:38 PM
IgniteTeg's Avatar
Default Re: Changing the Oil Filter (ITyp3R)
yeah if your havin a hard time go buy the filter remover tool very easy looks very funny hehe good luck. Also make sure you flush out all the old oil before doin all this.
Old Aug 1, 2001 | 08:59 PM
no_limit's Avatar
New User
Default Re: Changing the Oil Filter (IgniteTeg)
Thanks for all your input guys! I'm going to look into those oil filter wrenches then. I've also seen those sure-grip filters from Fram. They look pretty interesting as well. Now all I need is to get that damn OEM filter outta there!
Old Aug 2, 2001 | 01:18 AM
keys's Avatar
hahaha if worse comes to worser, a last option can be to jab a screwdriver into the filter and turn..... it's pretty blunt but it works
Old Aug 2, 2001 | 02:00 AM
ingrate's Avatar
25 Year Member
3. Always install the filter by hand first... Then tighten to 16 Ib-ft...
How would you measure exactly 16 lbs/ft of torque when tightening down an oil filter? Do you use that oil filter cap from honda that was mentioned above earlier? and even then i don't think i could fit a torque wrench up there
Old Aug 2, 2001 | 03:44 AM
Hapa DC5's Avatar
Default Re: Changing the Oil Filter (In7egrity)
wow i never have a problem taking off my filter, replacing it always seems to be a hassle, i dunno why. the filter just doesn't want to catch with me i guess, plus i barely have any room under my car when i jack it up...
namewasdallas
Jun 2, 2010 08:48 AM
yoitz2tone
Acura TSX
30
Jan 22, 2009 07:42 AM
mrchevez
Aug 7, 2008 02:52 PM
EKB18BPR3
Aug 18, 2002 02:43 PM
Type Goch
Jul 1, 2001 10:11 AM
