phearable.net Ecu chip problem
Old Feb 15, 2009 | 11:33 PM
en00be's Avatar
Default phearable.net Ecu chip problem
So i installed a phearable.not ecu chip with Launch control at 4500 and CEL shift light at 7
none of this works
did i install it wrong or something?
this post will probably be worthless cuz il just get hated on for being cheap or some shyt
Old Feb 15, 2009 | 11:42 PM
KillBot's Avatar
Default Re: phearable.net Ecu chip problem
I have no idea...
phearable is a good company...I would contact them. They have a great reputation and I have never heard a bad word about them.
You didn't install a ZIF?
Old Feb 15, 2009 | 11:47 PM
trustdestruction's Avatar
you have to install more than just the chip
you have to put 0.1uf capacitors on C51 and C52, a 1k ohm resistor on R54, a jumper on J1, and install some other weird chip next to the 28 pin chip.
and +1 on the ZIF... now you're gonna have to desolder the chip if you ever swap chips or get a tune
why didn't you buy the kit? ...
Copied straight from phearable.net's tech section:
Old Feb 16, 2009 | 12:20 AM
mr.k24's Avatar
just put the 1kohm resistor on r54 spot and the j1 jumper use one leg of the 1k resistor to j1 spot ho and you need the 74hc373 also i jave all that if you want it i can help you ok pm me
Old Feb 16, 2009 | 12:23 AM
you still need the capacitors.
Old Feb 16, 2009 | 04:59 AM
danomatic93's Avatar
lol, yeah you need those capacitors, the resistor, the IC chip (74HC373), and most importantly, you need the jumper (plain wire, no resistance) across J1. The jumper J1 is what turns the whole fuel map on!
Old Feb 16, 2009 | 09:50 AM
en00be's Avatar
can i get a radioshack parts list please?
Old Feb 16, 2009 | 10:30 AM
Bangher4$'s Avatar
the capacitors are not a must have, although you shuould use them.
The ecu is not set-up to run vtec either, dont know if you got a vtec chip or not.
Old Feb 16, 2009 | 10:51 AM
en00be's Avatar
no i dont have vtec either so what do i need to use this chip? (from radio shack)
Old Feb 16, 2009 | 11:23 AM
0.1uf capacitors (2 of them) on C51 and C52,
a jumper on J1 (use leftover leg from the resistor)
IC 74HC373 (IDK what that means and if it's the name of the chip or what... I just bought the kit)... idk if radioshack has these because idk what that technically means.
also try to get a ZIF socket.
Old Feb 16, 2009 | 12:14 PM
en00be's Avatar
ok thanks
civicsirii
Engine Management and Tuning
Jul 31, 2018 11:36 AM
Ejalldaipesos
10
Dec 5, 2006 12:56 AM
revlimitcrx
Apr 13, 2006 02:17 PM
C M S
Nov 26, 2003 07:42 PM
91 POS
Sep 5, 2003 03:34 AM
