dsm injectors?
Old Feb 14, 2009 | 08:45 PM
88crxdxfastwhip's Avatar
Default dsm injectors?
i have a 91 integra obd0 b18a1 i just got some injectors from a 97 5 speed gst. will they bolt right up or do i need somthing else?
Old Feb 14, 2009 | 09:04 PM
Default Re: dsm injectors?
bump
Old Feb 15, 2009 | 12:06 AM
XxNampsterxX's Avatar
You're gonna need to get a resistor box, obd1 clips, and need to shave the o-rings.
Old Feb 15, 2009 | 12:14 AM
Jimmy's Avatar
Global Moderator
You can do the resistor box or run the 10 watt 10 ohm resistors. I'm runnings dsm 450cc blue tops on my obd 1 teg with boosted b20b.. I used 10 watt 10 ohm resistors from radio shack..
The injectors are larger.. so it's ideal to take a dremel and trim up the injector o-rings.. Also my clips wouldn't fit, but all you need to do is take a hobby knife and notch the little lip off down inside the injector.. real easy.. then they plugged right up.
http://www.homemadeturbo.com/tech_pr...ors/index.html
Old Feb 15, 2009 | 12:27 AM
Jimmy's Avatar
Global Moderator
Yeah.. whoops you might wanna disreguard that.. I'm not sure if this works on obd-0 cars
Old Feb 15, 2009 | 05:13 AM
StokelesS_g2's Avatar
It's about the same.
OBD0 already has a resistor box. All you need are the right clips, and trimming as mentioned already.
Old Feb 15, 2009 | 06:18 AM
what seals do i need to use do i buy them for an eclipse or integra? and when i shave the seals do i bore them out or cut layers of it off?
Old Feb 15, 2009 | 06:43 AM
bump
95dc2teg
Jul 29, 2006 11:01 PM
MBlake55
12
Jul 2, 2006 03:59 PM
Smooth-GSR
Mar 26, 2004 10:16 PM
Happyman
Jul 7, 2003 06:37 AM
teg92
Dec 13, 2002 11:08 AM
