CEL codes P0170 and P0171
Old Feb 14, 2009 | 06:49 AM
eskimo10's Avatar
Default CEL codes P0170 and P0171
Ok, ran it again at Autozone with their scanner, and they pulled the codes P0170 and P0171. Basically my fuel system was too lean in bank 1 (I think it said bank 1). Car is a mostly stock 98 Civic EX. I say mostly b/c I have an I/H/E combo but thats it.
Where should I start at first? I ended up not replacing the o2 sensor, but I can if thats part of the problem. I've read else where after searching, that it could be the o2 sensor, fuel filter, check fuel pump, fuel feed pipe, fuel pressure regulator, fuel return pipe. Any suggestions as to where I should start first? Any help is greatly apprciated.
Last edited by eskimo10; Feb 17, 2009 at 04:22 AM. Reason: New problem/Mispelled Title
Old Feb 14, 2009 | 09:31 AM
davefromPA's Avatar
Default Re: Bad o2 Sensor.
not sure what would kill the o2 sensor but the one from the dx will work just fine
Old Feb 14, 2009 | 10:20 AM
eskimo10's Avatar
OK cool thanks davefromPA.
Anyone know of any thing that would kill an o2 sensor so quickly? Engines been tuned up with regular oil changes, don't really beat on it, but I did get on it a bit yesterday when I popped the check engine light. Any help is greatly appreciated
Old Feb 16, 2009 | 04:41 AM
eskimo10's Avatar
Default Re: CEL sodes P0170 and P0171
Bump. New problem.
Old Feb 17, 2009 | 04:21 AM
eskimo10's Avatar
no body knows anything about these CEL codes?
Old Feb 18, 2009 | 06:18 PM
eskimo10's Avatar
Default Re: CEL codes P0170 and P0171
one last bump before I go ***** to the wall and look at possibility
Old Jul 21, 2009 | 07:45 PM
Lithel's Avatar
All I know is that I have the same problem on my 99 Integra. P0170 and P0171, anyone got any good tips on where to start?
bLu92bUbbLe
Sep 9, 2010 07:27 PM
Defiant_dc
Oct 12, 2008 08:29 AM
Ricey McRicerton
Sep 29, 2003 10:04 AM
ORcivicsi
Sep 12, 2003 09:35 AM
BoostedGSRBubble
Mar 24, 2003 08:46 AM
