Help w/ codes 41 & 43
Old Mar 23, 2003 | 03:54 PM
BoostedGSRBubble's Avatar
Default Help w/ codes 41 & 43
The codes are for my o2 sensor/heater circit and a faulty fuel supply. The codes go away when i shut the car off and come on randomly while cruising. Sometimes its only the fualty fuel supply code. They are happening more and more frequently. Im missig one of those little brown spacers that go between the fuel rail and te IM. Could the vibration cause the codes? Any other ideas, ive double checked everything i touched concerning the fuel system and its all fine. Could my o2 sensor be going bad? Thanks for any help.
Old Mar 24, 2003 | 08:46 AM
Flamenco-T's Avatar
Default Re: Help w/ codes 41 & 43 (BoostedGSRBubble)
try to change the plugs, and check the gap, then reset the ECU and see what happens, you may have a foul plugs and running a lil rich or leaner than normal..
if it still happening again, try to swap O2 sensor to see if it helps any
stan
dansaleen_04
Jul 10, 2006 05:37 PM
boostinh22
Nov 29, 2005 11:15 AM
Street Inc
Jul 25, 2005 12:14 PM
acurakid6786
Feb 10, 2005 10:00 AM
Ricey McRicerton
Sep 29, 2003 10:04 AM
