Fuel + Spark still no fire
Old Feb 13, 2009 | 07:01 PM
tfeagley's Avatar
Default Fuel + Spark still no fire
Here is the short version. B16a swap into my ej6, Got spark, got fuel but the motor just cranks and cranks. Had to use a jumper to get the fuel pump started. Not sure the issue there, has power in both fuses just seems to have an Open somewhere connecting to the fuel pump harness. Going to check compression tomorrow since the battery finally died.
Tell me how dumb I am and give me an easy fix. Thanks!
Old Feb 14, 2009 | 03:13 PM
tfeagley's Avatar
Default Re: Fuel + Spark still no fire
anyone?
Old Feb 14, 2009 | 03:47 PM
tx_ej8_49's Avatar
Fuel, air, spark.
If you have fuel at the rail, all the plugs are firing, and your are on planet earth where air is somewhat abundant(spelling is not though), id check compression like you said, and timing. Even if the timing is off it should attempt to start but not idle in most situations. Thats about all the help i can give you right this second.
Old Feb 14, 2009 | 03:50 PM
Former User's Avatar
Yeah, check compression and whether the timing belt slipped.
Old Feb 15, 2009 | 12:28 PM
cruizinmax's Avatar
also check firing order on spark plugs
Old Feb 16, 2009 | 01:57 PM
97civic07gsxr's Avatar
also if u ran a jumper to fuel pump to get it to work and there is a ground then your injectors could not be working, i think they are on the same circut as the pump is, or at least they are in mine.
famdakam
Feb 12, 2017 11:32 PM
H22SHtec
May 5, 2011 02:59 PM
d16z6civic811
Dec 7, 2010 07:06 PM
fcluddington
11
Sep 24, 2009 09:50 PM
krazie1
Oct 29, 2003 10:58 AM
