Help Calculating Compression
Old Feb 12, 2009 | 08:53 PM
Boosted_B_Series's Avatar
Default Help Calculating Compression
I need a little help and need to roughly calculate my compression for this season.
I have a few things in my setup that changes compression a bit.
Please correct me if any of my figures are wrong.
My setup:
ITR head
High compression skunk2 valves
GSR Block
LS Crank/Rods
GSR CP pistons
If my maths right:
High comp valves add + 0.4:1 compression
GSR CP pistons with LS stroke add + 0.5:1 compression
So If I use 9:1 pistons I land somewhere in the 9.9:1 compression range.
I do not know any rough calculations for the ITR head on the GSR block
Any insight, comments or suggestions on this will be greatly appreciated.
Thanks for your time,
DK
Old Feb 13, 2009 | 07:45 AM
tony413's Avatar
Default Re: Help Calculating Compression
just use a comp calc and type in the physical measurements you have
.adam.
Mar 2, 2007 03:39 PM
Teal_Coupe
Oct 16, 2005 05:12 PM
Kellindal
Dec 22, 2001 07:38 PM
speedymon
Dec 19, 2001 04:42 PM
