94' Swap Issues
Old Feb 12, 2009 | 07:21 PM
SofireGuy's Avatar
Default 94' Swap Issues
Hey guys. I couldn't find my other post on the tech/misc forum so I thought I'd post it on here. I swapped a 97 Engine into my 94 accord. I kept it on OBD1 with the old harness and kept my Distributor and fuel rack.
As most know, honda switched up to a non vacuum operated IAT sensor that mounts with 2 bolts on the intake. Now, since I kept is on OBD1 i still have my vacuum operated one that is suppose to have a vacuum hose on the intake directly and one on the air box. I don't have my old intake so there's no place for it on the 97 engine in the intake.
Does anyone know what I can do to get around this?
Also, I found out this engine I bought isn't making compression, possibly cracked block or head gasket since all of the coolant that I poured in today went straight to the oil pan. What do you guys think?
Old Feb 13, 2009 | 04:49 PM
BlUAc's Avatar
Default Re: 94' Swap Issues
well looks lyk uur fubared y dont u just take uur motor back an try 2 get the ryt motor u need
Old Feb 14, 2009 | 08:40 AM
Turbowa's Avatar
If your oil pan filled with coolant when filling the radiator I would fix that first. But the vacuum hose is an easy fix. Just T-off one of the other factory vacuum lines and you'll be fine.
SofireGuy
Engine Management and Tuning
Feb 11, 2009 12:04 PM
keep_h8n
Dec 25, 2008 03:06 PM
SMOOTHN
Mar 31, 2007 11:55 PM
20civic00
Mar 6, 2006 06:30 PM
mugenspoongsr
Jul 1, 2005 08:35 PM
