Oil poured straight into my compressor inlet, am I screwed?
Old Feb 12, 2009 | 04:09 PM
EGTurboB16's Avatar
Default Oil poured straight into my compressor inlet, am I screwed?
Running a boosted B16 and shot my dipstick out and poured oil all over the front of my engine, some of which got into the compressor and there's now oil all in my intake manifold and intercooler piping. Is it just a matter of cleaning everything up or should I just give up now and start parting out what I can. I do not have the resources to rebuild the engine if thats the case.
Old Feb 12, 2009 | 04:12 PM
srmofo's Avatar
Default Re: Oil poured straight into my compressor inlet, am I screwed?
I would say your bigger concern is the crankcase pressure high enough to push the dipstick out, what are you running for pcv ventilation? clean the oil out of the intake and pipes and do the best you can with the compressor but I wouldnt spray to much solvent into it, replace the plugs if they are fouled and see how she does....you have to vent the crankcase better.....or you have blowby issues
Old Feb 12, 2009 | 04:13 PM
boostedcivicsir's Avatar
Mr. Badwrench
Originally Posted by srmofo
I would say your bigger concern is the crankcase pressure high enough to push the dipstick out, what are you running for pvc ventilation? clean the oil out of the intake and pipes and do the best you can with the compressor but I wouldnt spray to much solvent into it, replace the plugs if they are fouled and see how she does....you have to vent the crankcase better.....or you have blowby issues
i would definately start there.
Old Feb 12, 2009 | 06:19 PM
EGTurboB16's Avatar
Thanks for the advise, I'll do all that and see where I stand.
Old Feb 12, 2009 | 07:59 PM
srmofo's Avatar
what are you using to vent the crankcase?
Old Feb 12, 2009 | 10:02 PM
Boosted_B_Series's Avatar
he'd right buddie, get your crankcase pressure issue sorted out. A little oil in your turbo is the least of your concerns.
ryguy2588
Jun 9, 2011 02:27 PM
Tuesday Club
Aug 17, 2006 08:09 AM
purpleh22
Feb 15, 2006 08:20 AM
teddy_dc2
Oct 11, 2005 08:04 PM
