Oil in intake to intercooler
Old Feb 14, 2006 | 09:41 AM
purpleh22's Avatar
Default Oil in intake to intercooler
During some work on my H22, found oil in the tubing from the turbo to the intercooler. (Using a GT30 @ 10 lbs. with occasional jump to 18 lbs.) Enough oil to get a dark line or small accumulation on my finger when swiping the inside of the tube. About 2000 miles since install, car blows smoke @ upper end of rev range, oil not visible @ intake man. side of intercooler. Shop where I bought turbo said some oil blowby is common. Comments?
Old Feb 14, 2006 | 03:58 PM
purpleh22's Avatar
Default Re: Oil in intake to intercooler (purpleh22)
Is the seal on the turbo bad? Do all turbos leak enough oil that you can see it?
Old Feb 14, 2006 | 07:51 PM
Soccerking3000's Avatar
what feed line are you running?i would look into getting an oil restrictor just tomake sure there isnt too much oil pressure
Old Feb 14, 2006 | 08:26 PM
voltronR34's Avatar
Sounds like too much oil pressure to the turbo. BB turbos need a restrictor.
http://www.atpturbo.com
Old Feb 14, 2006 | 11:29 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default Re: Oil in intake to intercooler (voltronR34)
blown seals in both the turbine (blown smoke) and compressor (visible oil in piping), i recommend a -3 oil send line and -10 oil drain.
Old Feb 15, 2006 | 08:20 AM
purpleh22's Avatar
Default Re: Oil in intake to intercooler (JDM turbo DC)
Thanks for the information.
EJ8Squad919
Dec 22, 2012 11:36 PM
VanHonda
Nov 25, 2003 10:07 AM
Lenthrax
Jan 31, 2003 10:00 PM
BLKMamba
Aug 21, 2001 07:47 PM
