dreaded subframe tearout.
Old Aug 9, 2002 | 03:30 AM
slimbo's Avatar
Default dreaded subframe tearout.
i am now a victim, anyone here had it happen?
is it expensive to fix?
i was checking it thoroughly this afternoon, doesn't look TOO complicated to fix.
problem will be getting compensation of the company that manufactures the swaybar.
Old Aug 9, 2002 | 03:46 AM
Scary1109's Avatar
Default Re: dreaded subframe tearout. (slimbo)
what are the details, how did this happen, what were you using for a sway bar?
i hope your car repairs go well.
Scott
Old Aug 9, 2002 | 03:50 AM
slimbo's Avatar
Default Re: dreaded subframe tearout. (Scary1109)
bit of a racetrack battle scar
i finnished up for the day and noticed a squeaking from the rear of the car. subfram tearout was the first thing to go through my mind.
it hasn't broken away yet, but there is a crack at the top of the swaybar braket, and the bracket has broken free down the bottom.
i was using a 19mm swaybar that is designed for the factory brackets. the shop *promised* me this would not be an issue. let's see if they are going to say when i show this to them.
Old Aug 9, 2002 | 03:59 AM
Scary1109's Avatar
ouch!!! i hope all goes well for you. good luck
Old Aug 9, 2002 | 04:01 AM
slimbo's Avatar
thanx
seowitz
16
May 21, 2008 02:56 AM
iH8RICERZ
Suspension & Brakes
25
Aug 17, 2007 04:33 PM
92_prelude
Apr 16, 2007 05:17 PM
JunY
34
Feb 9, 2006 04:43 PM
RAK
Sep 24, 2005 07:34 PM
