stripped block
Old Feb 12, 2009 | 01:53 PM
biggoofy's Avatar
Default stripped block
the drivers side holes in the block where the motor mount attach are stripped does anybody have experience with this i need help do i need to pull the motor or can i just use an engine hoist to hold it and retap the holes
Old Feb 12, 2009 | 02:07 PM
LS stretch's Avatar
Default Re: stripped block
pretty sure your gonna have to pull the engine out to get the angle right when re-tapping.
i had an engine built once and when they shipped it back to me the part of the block your talking about cracked off on one of the holes. i ended up having to drill the holes out bigger and tap them with a bigger size to make everything work. drilling through the cast block mount was a BITCH tho.
Old Feb 12, 2009 | 02:46 PM
biggoofy's Avatar
there is nothin on either side of it i have no ps or ac the timing belt is the only thing that might be
Old Feb 12, 2009 | 03:40 PM
ruffrhyder's Avatar
You can raise and support the block from underneith with a jack and a big block of wood. I did this myself and was able to tap and repair all 3 bolt holes for the driver side motor mount.
Old Feb 13, 2009 | 06:12 AM
biggoofy's Avatar
awesome i will try this tomorrow im worried i will have to drill out and go bigger which is really gonna suck
Old Feb 13, 2009 | 06:16 AM
ruffrhyder's Avatar
That's what I had to do.
Old Feb 13, 2009 | 06:31 AM
biggoofy's Avatar
how hard was that to do
Old Feb 13, 2009 | 06:53 AM
qazaq's Avatar
helicoil, that's what u did just recently. hope it holds
i thinks it's m10 with 1.25 step
Old Feb 13, 2009 | 10:23 AM
ruffrhyder's Avatar
Helicoil, no way, I used a Time sert. It's been almost 2 years and almost 50k miles later, still no problems.
Old Feb 13, 2009 | 06:28 PM
biggoofy's Avatar
where can i buy a helicoil
TGonie
Welding / Fabrication
Aug 3, 2013 02:05 PM
1993-eg1
May 1, 2010 03:23 PM
teamitr
Nov 17, 2005 07:09 PM
stickyfingers
13
Feb 8, 2005 04:50 PM
sohczchf
Nov 16, 2004 12:08 PM
