How rich is too rich?
Old Feb 12, 2009 | 06:33 AM
gshatch's Avatar
Default How rich is too rich?
I installed a aem uego yesterday. Just driving down the road it is readding 13.8-14.2.
idle 12
wot 10.2
What would you consider too rich?
B20 block, gsr head, skunk2 cams stage 2, 70mm throttle body, intake manifold
mugen header and megan 2 1/2 exhaust
Old Feb 12, 2009 | 07:15 AM
GhostAccord's Avatar
Default Re: How rich is too rich?
What are you using for tuning?
Idle = 15-16 no need to run rich at idle, it's better on your pocket book to run it a bit on the lean side.
Cruising = 14.7 again same thing, no need to throw gas out your tail pipe while your cruising around.
WOT = 12-13 but that all depends on your tune & engine setup.
A dyno is where you will find out what the best AFR's are for your setup.
Old Feb 12, 2009 | 08:27 AM
sander's Avatar
2.7(p/t)
Yes, that is too rich at high load.
Old Feb 12, 2009 | 11:17 AM
drewbie57's Avatar
You're going to love your car after you get it tuned, lol. There will be so much more power after getting the right AFRs and locking down the ignition.
Just make sure you find a reputable tuner, and if you're doing it yourself, read lots and make a knock listening device ASAP (aka det can).
The rest can be solved with the search button and some light reading.
Old Feb 12, 2009 | 12:30 PM
gshatch's Avatar
yeah my ouncle is the one who has been tuning honda for a long time and i have a lot of trust with him. the only problem is his work scheduale.
we are going to street tune it for now. I plan when it gets warmer mid 50 finishing it with some dyno time
I have a Field SFC contoller and hondata S200. The only reason i bought the Field SFC controller is for an accurate rpm gauge.
Old Feb 12, 2009 | 05:41 PM
mn_babyboy's Avatar
your idle and WOT are too rich.
Old Feb 13, 2009 | 07:06 PM
Chicas's Avatar
yup everythings quite rich
for idle, i set mine at 15s to 16s
cruising, i go for mid 14s
WOT, low to mid 13s (for NA)
just watch out for detonation, because I'm not sure where your timing is at.
get your car tuned! you'll enjoy it more, and it'll be easier on the pumps. goodluck
Old Feb 13, 2009 | 09:25 PM
I CRX I's Avatar
not to thread jack but my cars seems to breack up whenever in anything higher then 14.5, should i advance my timing to counter act the breaking up? it happens both when cruising oor at idle. its not a big stuter but when cruising you can feel a very slight loss in power when @ 14.7 or higher.
Old Feb 15, 2009 | 12:01 PM
hoya_10fintec's Avatar
It sounds like it's your timing..
StavinE
22
Sep 18, 2013 01:23 PM
Jhicks
Jan 25, 2012 07:06 AM
littleblue
Sep 2, 2009 03:36 AM
xfrankx
Aug 26, 2006 08:57 AM
