nitrous questions
Old Aug 8, 2002 | 09:41 PM
lsvtec94's Avatar
Default nitrous questions
i am building a motor and i want to run a large nitrous system, but im not sure on how big to go. i have crower econo billet rods with endyne 12.5:1 compression pistons, the motor is an lsvtec combo it has will have lsm cams with lsm valve springs and supertech valves. the nitrous kit will be a direct port fogger system, probably progressive... i did not get the block sleeved but i did purchase a zten block girlde to strengthen the block. the nitrous kit will only be sprayed wiht race gas or i will have a sepereate tank wiht race gas in it for the nitrous kit. alls i need to kwno is how large of a shot i will be able to run.. i have heard up to 150 from some peopel and from others i have just heard 110-120. i am just starting get the rest of the stuff done on my motor and i need to find out what it is capable of handling... if anyone has any advice i would appreciate it thanks.
Old Aug 8, 2002 | 09:58 PM
MooreBoost's Avatar
Default Re: nitrous questions (lsvtec94)
What dd it cost you for the v-tec heads, solenoids and all that other ****, installed?
gmoore
Old Aug 9, 2002 | 02:33 AM
lsvtec94's Avatar
Default Re: nitrous questions (gmoore379)
i bought a complete b16 that i had in my car before i did lsvtec so im not sure bout the heads but the total was liek 2 grand for everythign including machine work... i got alot of stuff for free and stuff that i didnt get fro free i got for a good price
Old Aug 9, 2002 | 02:38 AM
kinesistech's Avatar
After the Rods and pistons, the cylinder walls are next. I saw a guy blow his engine built for NOS on a 150 shot. I think that may do the same for you. Be careful.
Old Aug 9, 2002 | 06:10 AM
LshatchTurbo's Avatar
New User
Default Re: nitrous questions (kinesistech)
If you want to run a big shot, with that high compression, I would look into the new EFI direct port nitrous set-up from NOS. Looks pretty promising, but kinda pricey for a NOS kit.
Old Aug 9, 2002 | 06:15 AM
eTec's Avatar
Default Re: nitrous questions (lshatchturbo)
Why don't you start with a 100 shot and go from there? Tuning is the key. Read your plugs after each run. If they look good slowly up the shot. Put it on a dyno and check your a/f ratios. Which nitrous controller are you going to use?
Old Aug 9, 2002 | 08:12 AM
TREVER's Avatar
I think your c/r is too high for any nitrous.
I run 11.2 c/r and a 100 shot and I'm waiting for my sleeves to crack
Old Aug 9, 2002 | 08:51 AM
slickboy's Avatar
New User
Default Re: nitrous questions (eTec)
You will most definately need 2 steps colder spark plugs, and they will need to be checked often. Higher compression and n2o work great together..just remember, tuning is the key!
Old Aug 9, 2002 | 08:58 AM
builthatch's Avatar
MiG-21 superfan
Default Re: nitrous questions (slickboy)
HIGH CR and N20 love doin' each other, if tuned properly...BUT, without sleeving, you are seriously compromising the integrity of those cylinder walls under that ridiculous cylinder pressure. YOU NEED TO SLEEVE IT. if you sleeve it and stud it, add stainless exhaust valves...you can run 150+ dp shot no problem, as long as your other tuning variables dont drop the ball...
Old Aug 9, 2002 | 12:30 PM
lsvtec94's Avatar
thanks for the advice guys it has been helpful and i think iw il just start with a 100 shot and work form there... i have having tom payne tune my car as soon as i get it put back together so im sure it will be tuned right... thanks for the advice and keep it comming..
Amped
Sep 25, 2006 04:18 PM
g-ride-si
Feb 2, 2006 12:16 PM
scUba-stEve
14
Oct 14, 2004 10:17 AM
evilk
Jul 29, 2004 07:06 PM
1.8EG-T
May 20, 2003 12:09 PM
