Del Sol Gauge Cluster Bulbs, wanting to upgrade!
Hey guys I am looking to upgrade the bulbs in my del sol cluster to LEDs. the "wide angle" ones.
What type of bulbs or size is the stock ones? and how many of each are there including the ones in the climate control?
Anyone who has done this please post your experience, It would be appreciated, thanks!
they're type 74 bulbs.
the one behind the gas/temp gauges though has less room though and most LED bulbs won't fit. For that I recommend wiring in your own 5mm blue LED by soldering it to the contacts on the back of the cluster and hot glueing it in place.
I'd us a 5mm LED from Oznium.com
so all the ones behind the cluster is type 74.
would you happen to know how many there are?
what about the Climate Control ones.
Thanks!
Thanks!
I'm pretty sure there are 8 of them(but don't quote me) in the cluster and I have no idea about the climate control. You might want to get on the DSOC thread and ask around
2 type 74 bulbs in climate controls, 1 type 74 in the shifter (if you have auto) and between 6-9 bulbs in teh dash, Not sure, but never hurts to have extras laying aroung around lol
Did you ever end up upgrading the bulbs in the cluster? If so what color did you decide to go with?
I am thinking about replacing these bulbs with a different color, I have a red del sol si. I think I might just end up replacing them with red bulbs but it would be awesome if anyone had any pictures of how it turned out.
EDIT:
here.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5Ddiy-96-98-amber-climate-control-cluster-56k-go-cross-country-1186091/
the other 2 links on the original post are for different years.
please use search button on top.
I don't remember all the bulb codes I got but they definitely do work. If you go to www.superbrightleds.com they have diagrams of all the types of gauge cluster bulbs, etc. If you pull the bulbs out of your cluster you can figure out which ones you need just by comparing them with the pictures. Here was mine when I finished.
oh yeah, and don't forget to pull this thing out of the top to allow more light to go through!
Hey I changed out my LED bulbs to red ones from superbrightleds but it seems that the left side of the clusters are dimmer than the right side. I haven't had time to check out what might be causing the problem. Has anyone else had this problem?
Jack 4TT4CK
Sep 13, 2013 07:01 PM
honda_racing101
20
Aug 7, 2008 12:47 AM
phantom_sol
Apr 10, 2003 10:41 AM
