rear defroster
Old Feb 10, 2009 | 08:02 AM
Civicme's Avatar
New User
Default rear defroster
hey guys. i have a 93 hatch. i just bought a new glass cause mine was shattered recently. i installed it and one side of the defrost plug broke off the glass. i was hoping having just one side plugged in would still defrost it but i guess it dosent. is there any way to get that fixed or am i gona have to get a whole new glass again?
Old Feb 10, 2009 | 08:04 AM
Unseen Racer's Avatar
Default Re: rear defroster
rear defrosters work by sending electrical current through those lines. which heat up.
and for it to heat up it needs a + and - current
just get the broken piece and solder it back on its previous position
Old Feb 10, 2009 | 09:08 AM
lee0149's Avatar
try soldering it back on. the wire.
Old Feb 10, 2009 | 10:52 AM
jay2020's Avatar
can those lines go bad? on my coupe the top quarter defrosts and then the middle doesnt and then the bottom does. both the connecters are attached. anyone have or had this problem?
Old Feb 10, 2009 | 12:13 PM
wheelmanbg's Avatar
OP: Loctite and/or Permatex make a kit so you can glue that piece back on. I don't soldering would work. Search amazon for rear defrost kit or something like that.
Old Feb 10, 2009 | 12:16 PM
wheelmanbg's Avatar
Yes, they can go bad. They are basically just painted on the inside of the glass. If anyone has scraped the inside of your window with a razor blade then your lines won't work. Also, cleaning with a harsh solvent would cause breaks. If you look real close, you should be able to see where they are broken. They make kits to repair them but it's a pain and sometimes doesn't work.
Old Feb 10, 2009 | 01:00 PM
Joel.'s Avatar
I C U P
Yeah I'm having the same problem in my coupe, it makes me sad
Old Feb 10, 2009 | 03:01 PM
Civicme's Avatar
New User
i searched for the permatex kit. i might go wtih that but how does that work? dosent really show or give a description.
Old Feb 10, 2009 | 05:00 PM
wheelmanbg's Avatar
I've never actually used the tab glue kit but I imagine it's just like an epoxy. I just remember seeing it when I was looking for the kit to fix the actual lines.
Angelsbeamer
11
Jul 28, 2017 03:24 PM
UgP
Jun 16, 2007 10:51 AM
mrdeadman
Jun 15, 2006 10:27 AM
Knightmare69
Dec 5, 2003 04:36 PM
skribblah
16
Jul 2, 2003 09:47 AM
