timing belt issue
Old Feb 9, 2009 | 07:43 PM
ef846's Avatar
Default timing belt issue
i have a b18a1 and i went through and followed the steps in a manual on how to tighten the belt but it didn't tighen it is still loose
id it the spring on the tensioner that s bad if it isn't tightening ir is there a specail technique to tighten it
Old Feb 12, 2009 | 09:41 AM
LSVTEC408's Avatar
Default Re: timing belt issue
Set everything to TDC(crank pulley and cam gear marks), make sure tensioner is loose. Install timing belt, here is the tricky part, to tighten the belt rotate the crank clockwise 3 tooth until u feel the belt tight, then tighten the tensioner. spin it clockwise twice and double check your marks. hope that helps.
dleccord
Apr 13, 2020 08:03 AM
giovannie23
Jul 20, 2013 11:52 PM
TravisCadello
17
Apr 18, 2009 06:18 AM
jvonb
Dec 18, 2005 07:47 AM
B2FiNiTY
15
Sep 10, 2003 07:47 AM
