EK wont start after Clutch job
Here is the situation. Replaced clutch, put everything back together and while it was still on jacks, we started the car and ran through the gears. Everything was good so we lowered the car onto the ground and now it wont start. I imagine it is a fuse somewhere because there is no check engine light when the ignition is turned to on. Also there is no fuel being delivered (can't hear it charging the injectors) The only lights that come on when the key is turned is the seatbelt light and the brake light (even if the e-brake is down). Any ideas??
This has me stumped. I have done many clutches and haven't ever ran into this. Thanks ahead of time
Forgot to add the car won't turn over. I tried tapping on the starter cause i thought it might have siezed up and that sometimes helps. But it started up once fine and now there is no power to the motor.
