oil light flashing on and off?
Old Feb 7, 2009 | 04:17 PM
heefro757's Avatar
Default oil light flashing on and off?
i have just put the first 20 miles on my stock rebuilt GSR. When i was driving home the oil light started flashing on every time i stopped and the motor went to its idle speed. but then it started flashing on quickly and randomly. it was only doing this the last mile of its 20 mile history. the oil level was fine and i am not seeing or smelling any leaks. any help would be appreciated.
Old Feb 7, 2009 | 05:32 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: oil light flashing on and off?
thats scary.. that usually means your oil pumps going bad or you got a bad sensor was the oil pump new or used?
Old Feb 7, 2009 | 05:56 PM
heefro757's Avatar
it is a new oil pump. it was after market though.... i did replace some sort of oil sensor on the back of the block know that i think about it. i let it run for about 5 mins and drove it around block several times and the light is not coming on. it may only come on for longer trips since it happened in its longest trip of its new life.
Old Feb 8, 2009 | 12:39 AM
wunfstgsr's Avatar
Loved
Community Favorite
if its new it could be defectedwhich would really suck a failed oil pump can cause a spun bearing you should deff. check that sensor im thinking it has a bad connection maybe when it gets to hot from a longer trip, check it out make sure its the correct one clean its surface i know its hard to get back there but do it. i always use oem oil pumps although i havent herd of any aftermarket pumps to go bad its not that common my 2 cents says theres something with that sensor check back with us.
Old Feb 8, 2009 | 06:56 AM
heefro757's Avatar
yeah im a noob and this was my first build.... lots stuff i wish i would have done differently. i will for sure wait to drive it till monday when i can put it on the lift at work... thanks for the advice ill let you know how it went.
Old Feb 8, 2009 | 01:55 PM
AnDThEnWuT's Avatar
It could be your oil pick up spout, I took mine out to clean the screen. Didnt correctly torque it and it came loose causing the oil light to flicker on and off. Took the oil pan off to find one of the nuts at the bottom of the pan. Check if your oil spout isn't loose.
Old Feb 8, 2009 | 04:19 PM
heefro757's Avatar
speaking of oil pick up spout when i was building the motor with a help of a mechanic i noticed the pick up was a little bent along with the oil pan. there was also a oil line added onto the oil pan from a previous turbo build ,but the mechanic said it would be alright to use... dont know if that could have anything to do with it.
Old Feb 8, 2009 | 04:32 PM
sp00ledbseries's Avatar
your oil pump might be taking a ****. and when they go they take things with them
92 CiviC H.B
Apr 26, 2010 02:56 PM
psegs80
May 19, 2008 07:44 PM
Vtecme92
Jul 31, 2006 03:31 PM
toooslow
Jul 8, 2003 10:59 PM
Cashflo
Apr 25, 2003 07:40 AM
