Honda S2000 Honda S2000
Loud transmission and Jerks
Old Feb 4, 2009 | 08:09 PM
CNSK's Avatar
Default Loud transmission and Jerks
Hi all,
I have a 01 and I have been noticing this problem but never had a chance to post it. I notice that when I shift gear I get a loud clunk noise - loudest in 1,2,3 gear. Shifts smooth and no grinds. Not sure if this is a common. My second problem is, my car jerks or bogs every now and then. For example, if I'm in second gear at 10 mph easing off the gas pedal, it jerks back and forth hard enough to where it looks like a rookie learning to drive manual. Any input is great. Thanks
Old Feb 4, 2009 | 08:12 PM
dagle's Avatar
Default Re: Loud transmission and Jerks
lol... the s2k has a direct drop-in tranny, its suppose to clunk. (the tranny is directly under the shifter)
and when you let off the gas im assuming you mean with the clutch still disengaged, and thats perfectly normal as well. the tranny's dragging, put it in neutral and it'll roll smoothly (or clutch in)
Old Feb 4, 2009 | 08:21 PM
CNSK's Avatar
Thanks, I guess its normal for the clunking noise. As for the car jerking, I normally do put it in neutral and let the car roll. I came from a teg and never had this happen. Still learning this car..........
Old Feb 5, 2009 | 05:07 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
how many miles on the car???
replace your tranny fluid if you dont know when the last time this was done...
Old Feb 5, 2009 | 05:38 PM
CNSK's Avatar
about 65k. Have no idea when the tranny fluid was change but its about that time......oem fluid? or gm?
Old Feb 5, 2009 | 06:22 PM
AP1_man's Avatar
i'd go ahead and change it and stick to the Honda tranny fluid. they use a better fluid since the last time you car probably was changed. might as well change the diff fluid also...
Old Feb 6, 2009 | 11:23 AM
Mohamad's Avatar
I hear similar sound when I take off gaz pedal, on third gear mostly...right ???
Old Feb 7, 2009 | 08:16 AM
CNSK's Avatar
2nd and 3rd..........
Old Feb 10, 2009 | 11:51 AM
White Smoke's Avatar
i my honda
Global Mod
The jerking sounds like it could be a map sensor issue.
Check this out, Map Wack info.
Old Feb 10, 2009 | 05:40 PM
h_s's Avatar
h_s
Check your motor mounts
Old Feb 10, 2009 | 07:35 PM
AP1_man's Avatar
^^^motor mounts wouldn't cause a clunk noise once the clutch engaged...he didn't mention vibrations when car is in idle...that doesn't seem to be the problem.
Old Feb 11, 2009 | 01:06 PM
sreyneng's Avatar
haha the same thing happen to me. i have an 03 and when i first got it..i was like wtf cuz i was used to driving my husband's DC5 and it never jerks in 1st or 2nd going at lower speed but because the S is made to be at a higher rpm, you kinda have to stay at a higher rpm to keep it smooth...so say if you want to avoid the jerking try not to stay in 2nd gear unless you're over12 or 13mph ...3rd gear over 20mph. you'll get used to it. as for daily driving and wanting to safe gas...as this is what i have to do ..rev to 4k before shifting...it runs so smooth and gas won't go from full tank to half a tank in a day lol. good luck!
Old Feb 12, 2009 | 05:12 PM
CNSK's Avatar
thats what I have been doing......i guess its normal?
Old Feb 13, 2009 | 07:55 AM
sreyneng's Avatar
it's very normal. it sucks in the beginning cuz i wasn't used to it...im stuck in traffic everyday for at least 40mins each way so i'm mostly going first and second gear lol kinda sad cuz ap1..u can rev to 9k! damn traffic.
DrewBrews
Mar 6, 2011 02:16 AM
jdmej814
Jul 26, 2009 05:05 AM
nicehatchy
Sep 22, 2005 09:33 AM
JuicyJDM
Jul 13, 2005 03:34 PM
