my teg will start but wont go.
Old Feb 4, 2009 | 01:39 PM
deadstock's Avatar
Icon6 my teg will start but wont go.
yesterday i was drivng to work then my car stalled out. so i pulled over started the car and it was idling at about 300 rpms i let my car warm up thinking it was maybe the cold weather effecting it, so as soon as i stepped on the accel my car stalled out. so i started up my car again then it did the same thing. i checked my feul pump and it works, everything in the fuel system works cuz spark pluggs were soaked so obviously its some where in the ignition. has any 1 ever had this problem??? please help ive been catching rides and is sux im sure some of u can relate to this.
Old Feb 4, 2009 | 02:41 PM
josh_mac17's Avatar
Default Re: my teg will start but wont go.
Check your TPS and MAP sensors.
Old Feb 4, 2009 | 04:52 PM
mpls's Avatar
will it start and stay on idle? so it dies when you give it gas?
Old Feb 4, 2009 | 07:37 PM
deadstock's Avatar
yeah its idling at about 300 rpms extremly low. my car wont stall untill the instance i give it gas. i just checked for spark n it has good spark. i have a b&m feul pressure reg on it. also my thermostat is stuck open. im goin to change tht out tomorrow morn. im thinkin mabe the teg is getting flooded out. what do u think? u think my feul pump may be bad? thanks for the advice
Old Feb 5, 2009 | 01:37 AM
Cameron60's Avatar
Old Feb 5, 2009 | 05:55 AM
96lsvtec-t's Avatar
Old Feb 5, 2009 | 07:37 AM
mark pones's Avatar
i had a B&M fpr an it went to crap reeeal quick swapped over to AEM an it runs fine
Old Feb 5, 2009 | 07:51 AM
PandaSJ's Avatar
Did you do any work the day before that you think might have done something?
Old Feb 5, 2009 | 08:38 AM
mouab18c1's Avatar
any CEL?
Old Feb 5, 2009 | 09:04 AM
deadstock's Avatar
no i didnt do any work. i checked my dizzy seal n it was shot also its been cold as helll here in TN so mabe there is moisture in my dizzy?? but i checked my spark n it looked good nice blue spark. i have the b&m feul press. reg. also. i woke up at 6;30 am went n got a new thermostat cuz it was stuck installed it installed new plugs adjusted the feul reg. still car didnt start. i got feul as well cuz plugs were soaked. im goin to get a feul pressure gauge tonite to read the psi. did ur b&m just stop working completely? or was it still giving gas? thanks guys
TinoNT
Jan 16, 2013 07:42 PM
Trung Nguyen
15
May 9, 2010 09:55 PM
93daintegra
Sep 16, 2008 01:21 PM
BlackHonduh
Feb 27, 2008 12:28 PM
SupaTegRS
Feb 27, 2003 09:10 PM
