First swap need help
Ok First off i got a 1990 Crx Si. Had a boosted d16. Now im going to step up to the B world. I would like to know what all i need for this swap i got. I got a b16 out of a 99 si. My biggest qustion is what wire harness i need. Or will i be able to use my stock. And will i need a jumper harness cuz its obd2 motor. My car already has a jumper harness that is obd0 to obd01. Or can i keep that in there and just get an obd01 Dizzy. Plz let me know
you can use your stock chassis harness and your ob0 to obd1 jumper harness will work.and yes your a obd1 dizzy. G/L
you could use the jumper you have now but you will have to tap into it for vtec, etc. then just get an obd1 b16 ecu, and obd1 distributor. you will retain the stock harness.
if you decide to chip the p28, xenocron has what you need
http://www.xenocron.com/stock-motor-...hip-p-323.html
shift linkage you would have buy it from hasport they make custom 1 (less headaches)and for axles use 90-93 integra axles.heres some info on swaps so you can get the idea.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/88-91-crx-ef-civic-frequently-asked-questions-faqs-1508680/
https://honda-tech.com/forums/showthread.php?t=1508680
94-01 Integra
99-00 Civic SI
or del sol with b16a3 (i think)
Bump ok i have another qustion. You said i need to tap into vtec but the harness i bought has a vtec conection already so do i still need to or no?
and can i us to stock clutch and flywheel on it on the new cable tranny i think i can cuz i used a d16 hydro clutch and fly wheel on my cable tranny i just want to make sure
Ok so i duno what to do. Im confused. From my i have the motor is all the clips in and all the hoses in but umm i have like 2 clips that have no where to go. What do i do with that lol. ill get pics but i duno is there things that the single cam has that the dual dont or what.
unautomobiled
22
Jul 30, 2010 03:21 PM
B16a2Wa
18
Jan 24, 2010 08:10 PM
SupraRXZ
Mar 10, 2006 06:37 AM
