93 DA having a couple of electrical problems...help!!
Old Feb 3, 2009 | 05:50 PM
aquito's Avatar
Default 93 DA having a couple of electrical problems...help!!
ok i tried to search but didnt find an answer..
Just got a 93 LS for 1k and this is the problems that it has...
my headlights dont turn on, i do one click on the headlight switch and dash lights and turn signal lights turn on like normal but when u do the second click to turn the lights they dont turn on...and the high lights do turn on but they will not stay in high..i have to keep pushing the switch back...where are the fuses for the low lights?? ohh and the fog lights dont turn either..
ok thats my first problem...now for the second is that my driver side seatbelt dosent work, my passenger works perfect but the driver dosent...the seatbelt is stuck in the position like when u open the door...i tried to operate it manualy to the position where it is when the door is closed and as soon as i opened the door the seatbelt goes down like it should but dosent go back up when i close the door...what can that be? where are the fuses for that??
and ac dosent work, its not like it dosent blow cold air, it dosent activate no ac or no fan nothing...
thanks
Old Feb 3, 2009 | 06:34 PM
j_bizach's Avatar
Default Re: 93 DA having a couple of electrical problems...help!!
First problem sounds like it may be ur door open and close switch that the only thing ur can do to fix that is to take the switch out and replace it or hard wire the spitch to read as the door is always closed
Old Feb 4, 2009 | 02:47 PM
aquito's Avatar
uptaded with pics...
ok so i checked # 3 and # 4 with my tester and they dont work, i changed the fuses and the same result, then i took the fuses out and sticked my tester inside and this are the results...
uper part of #4 has power just when lights are on + high beams on...will shut off power as soon as i put it in low beams...
lower part of #4 has no power when lights are on no matter if they are in high or low beams...
upper part of #3 has no power when lights are on no matter if they are in high or low beams..
lower part of #3 has power just when lights are on + high beams on...will shut off power as soon as i put it in low beams...
now i took off the connector that was pluged to the lights switch..
now what is this? i found it laying around
and a random pic of the fuses in engine compartment just so you guys can tell me if everything is ok there...
and found this connector underneath the dash and has this wire without any tape or anything what can it be??
another thing...i was installing my radio and there was a cable that previous owner was using i think for 12v but there was no power on it...but as soon as i did one click on the light switch it had power...weird??:read:
Old Feb 4, 2009 | 09:43 PM
da6forlife's Avatar
i had the same issue with the seatbelt on my passenger side. what i did (cause it's a safety issue) took it into acura and had them fix it. because that is something that can endanger a person. so see if they might be able to do it for you. just talk them into it being a safety problem. let us know how everything turns out.
Old Feb 5, 2009 | 06:50 AM
91akira's Avatar
Wow your car has alot of issues. About the fuse box in the engine, I have a GS 91. You have two foriegn wires coming out of the fuse box. You might want to check what those are. My gs doesn't have anything like that. And looks like you have a missing fuse on the left hand side of the pic.
Ohh and if you want quick answers to your problems, go to G2ic.com. Register and go to the electrical section. Theres this guy in there (FCM) whos a guru in this type of stuff. My 2 cents.
rdemel
Honda Civic (2001 - 2005)
May 15, 2017 05:26 AM
fourblades
May 7, 2015 09:18 PM
Corey Alfredson
Mar 16, 2015 07:12 AM
Pabs626
Jul 17, 2007 10:25 AM
stupidwhitecat
Nov 5, 2005 04:26 AM
