ITR MC & BB question
Old Feb 3, 2009 | 10:21 AM
5lug hatch's Avatar
Default ITR MC & BB question
I have searched H-T for some good info but not really finding the info I'm looking for. I was just wondering if I can use an ITR 1" MC and BB with a 40/40 prop valve in my CX EG to accomodate my itr 5 lug conversion even though my car is non abs or will I have to find a 15/16" MC and BB from a GSR non abs to fit my car. Thanks for any help and sorry if this is a noob question/thread.
Old Feb 3, 2009 | 10:38 AM
Mashimaro's Avatar
Default Re: ITR MC & BB question
The ITR MC/BB will work along with the 40/40 or the Si hatchback prop valve as well.
I'm using a 15/16 MC/BB and it works great on my Si hatch.
Old Feb 3, 2009 | 11:02 AM
5lug hatch's Avatar
My hatch is a CX though, non abs. Since ITRs and their parts are abs, I was wondering if I can still use them regardless of abs?
Old Feb 3, 2009 | 11:11 AM
Mashimaro's Avatar
yes, you can. i'm also running the 5-lug setup on my EG which never had ABS. that's why you may need the prop-valve as well since your EG has drums in the rears originally.
Old Feb 3, 2009 | 12:54 PM
5lug hatch's Avatar
So as long as I have the 40/40 prop valve I can use the ITR 1" MC and BB? Sweet, thanks for the info. Is there any flaring of lines or any kind of prep I need to do or do they all just fit? I've read that some bending of the lines is required am I correct?
Old Feb 3, 2009 | 02:02 PM
Mashimaro's Avatar
as long as you get the '98+ JDM ITR MC, all you'll have to do is bend one of the lines a bit (both EG lines are closer to the driver fender side, wherease one of the ITR ones is facing the passenger side).
the lines will also bolt rite up with the JDM ITR MC (both use 10mm flare nuts). becareful bending the hardline and make sure you don't kink it. you may want to be a pipe bending tool for this (cheap tool).
Old Feb 3, 2009 | 04:26 PM
5lug hatch's Avatar
Alright, thanks a lot Mashimaro. Another quick question: Can jdm and usdm MC and BB mix and match or no? I'm going to assume they can't but just want to make sure.
Old Feb 4, 2009 | 08:44 AM
Mashimaro's Avatar
i can't really answer that for you as i don't know. but i would assume they're the same for fit (as long as the mounting bolts for both JDM and USDM are at 3 and 9 o'clock).
spaceman00
13
May 2, 2007 08:53 AM
gino11
Apr 28, 2007 12:16 AM
The G2 Racer
May 11, 2004 09:26 AM
mikeweb
Feb 29, 2004 09:23 AM
