How to run 6PSI on a TDO5H-14B actuator
The spring in the actuator for a stock 14b turbo is set at 8-10 lbs.
I do not want to run this must boost on my setup until i get bigger injectors, fmu, and boost retard per lb.
How can i back the wastegate off to like 5,6psi? Can i find a small spring or something?
Thanks!
Thanks!
Silvertc
Aug 29, 2008 05:10 AM
sohc_turd
May 20, 2007 07:24 PM
Talon12bp
Nov 12, 2003 05:05 AM
