Tachometer Help
Old Aug 8, 2002 | 05:36 AM
A-LEX's Avatar
Default Tachometer Help
Dous anyone have a diagram or instructions on how to hook up my tach i have a 99 honda civic hatch dx thanks for your help
Old Aug 8, 2002 | 06:09 AM
Civic1992DX's Avatar
Default Re: Tachometer Help (A-LEX)
from what I can remember, Black is the ground, Red is +12V with Ignition ON, White is Illimination & the Green (is it green?) goes through the firewall to the distributor & solter it to the Blue wire (it's a signal wire).
Yuri K
Old Aug 8, 2002 | 09:52 AM
Kataku2K3's Avatar
Default Re: Tachometer Help (Civic1992DX)
Pull out ur cluster and just mess around with it. The only blue wire in the plugs on the back will be the one that you want to tap the green wire into. Find a good ground for the black wire. If you don't have a voltmeter then just probe around with the white wire turning your headlights on and off until you find illumination. I'm pretty sure illum. is red. Then get you main power from either igntion on in the fuse box or the back of the cluster. The last few tachs that i have put in for my friends have had everything tapped off the back of the cluster. It's just easier and cleaner.
FortunateFool.
Audio / Security / Video
Dec 14, 2007 10:46 AM
tanabe
Oct 14, 2006 02:18 AM
dungsta
May 22, 2005 08:16 PM
Gonzo_SiR
Oct 29, 2003 10:12 PM
preluder
Dec 22, 2002 09:51 PM
