sway bar question
I did a quick search but couldn't find what I'm looking for. I just need to know if a skunk2 sway bar and beaks sub frame kit for a 99 civic coupe will fit on my 94 civic ex. Thanks
if the sway bar was made for an EK, the d-brackets will be different and also the end links will be different as well.
i had one, and it doesn't really work on the EG chassis.
Cool Cool Island Breezes. BOY-EE
I have an ITR bar with integra brackets and EM1 links on my EM1.
you could be right.
however, i had an issue with an EK Skunk2 sway bar that i installed on my EG. the D-brackets on the swaybar were flat on the mounting point whereas the EG was recessed about 1cm on the lower bolt hole (used washers to fill it in and make the bracket line up straight). i've long since sold the bar off.
apekd
Sep 21, 2009 09:52 PM
spoonfed*ek9
Aug 25, 2008 01:27 PM
blackstar
Oct 25, 2004 09:26 AM
halim
May 11, 2002 12:25 AM
