sway bar question
Old 02-02-2009, 07:25 AM
08rampage's Avatar
Default sway bar question
I did a quick search but couldn't find what I'm looking for. I just need to know if a skunk2 sway bar and beaks sub frame kit for a 99 civic coupe will fit on my 94 civic ex. Thanks
Old 02-02-2009, 08:05 AM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
Default Re: sway bar question
The beaks kit is different for the 92-95 civics and the 96-00 civics. I'm sure the bar will fit, though.
Old 02-02-2009, 08:27 AM
Mashimaro's Avatar
if the sway bar was made for an EK, the d-brackets will be different and also the end links will be different as well.
i had one, and it doesn't really work on the EG chassis.
Old 02-02-2009, 11:46 AM
08rampage's Avatar
damn, I was hoping it'd work. Thanks for the info guys
Old 02-02-2009, 11:47 AM
Agent_EM1's Avatar
I find ones available for EG/DC all the time compared to EK's. Search around, you'll get another good deal.
Old 02-02-2009, 11:57 AM
B serious's Avatar
I'm pretty sure the D brackets are the same. If not, you just drill a hole into the EK subframe. You have to do that to install the ITR bar.
I have an ITR bar with integra brackets and EM1 links on my EM1.
Old 02-02-2009, 12:16 PM
Mashimaro's Avatar
you could be right.
however, i had an issue with an EK Skunk2 sway bar that i installed on my EG. the D-brackets on the swaybar were flat on the mounting point whereas the EG was recessed about 1cm on the lower bolt hole (used washers to fill it in and make the bracket line up straight). i've long since sold the bar off.
Old 02-02-2009, 12:52 PM
robfrmny21's Avatar
for a 92-95 civic use all **** from a 94-01 teg
96-00 civic you can use itr brackets and bushings and em1 end links
apekd
09-21-2009 09:52 PM
spoonfed*ek9
08-25-2008 01:27 PM
halim
05-11-2002 12:25 AM
Quick Reply: sway bar question
