Autometer Tach Wiring Help! (Already Searched)
Old Jan 31, 2009 | 02:33 PM
4gen4drcivic's Avatar
Icon6 Autometer Tach Wiring Help! (Already Searched)
I have a 89 civic sedan lx 1.5L. I hooked up the ground and power wires on my Autometer Tach. I just need to know what wires to hook up the signal wire and the light wire?
Old Jan 31, 2009 | 02:58 PM
slow88si's Avatar
Default Re: Autometer Tach Wiring Help! (Already Searched)
Did the tach not come with install papers?
rallypoint_1's Avatar
Signal wire to the distributor and light wire to headlight wires under dash.
Old Jan 31, 2009 | 03:50 PM
it didn't come with instructions. what color is the signal wire and lights in my civic
Old Jan 31, 2009 | 04:07 PM
Run the signal wire from the tach to the distributor. At the dist. make a hole in the rubber between the cap and housing. Run the wire through. Attach the wire at the coil. As for the lights I dont remember the exact wire but you can use a test light and probe around. As you probe turn the lights on and off and it should corespond with the test light. Anybody else have any other ideas. That worked for me.
Old Jan 31, 2009 | 04:49 PM
UndergroundTuning's Avatar
the green wire goes to the negative side of the ignition coil, there are two wires that are on the coil a the wire is yellow with a green stripe, just stip the wire and loosen the srew and put it under the screw, but make sure you dont have to much exposed wire to make contact with the positive side, and for the ilumination just connect it to the parking lights, because you can see it during the day, this has always worked great for me
Old Jan 31, 2009 | 04:59 PM
^ He explained it better than me. Not too hard to do. Good luck buddy.
Old Jan 31, 2009 | 08:53 PM
BiGZ's Avatar
What they said,but here'z a link to their install for most of their tachz...
http://www.autometer.com/download_instruction/1244.pdf
Old Jan 31, 2009 | 10:15 PM
thanks for the help guys. i'll try it out tomorrow
Old Feb 1, 2009 | 11:50 AM
apekd's Avatar
Here is a tip form when i did mine. attach the signal wire to the BLUE wire coming from the dizzy, try to find the wirer closer to the firewall to keep things clean. the for the light wire, might as well just get a wiring schematic and find the wire for the corner lights. thats all i did. took about a full hour to do. but then again i never did one before that.
Old Feb 2, 2009 | 09:23 AM
Clipsed's Avatar
Why run the wire ALLL the way to the dizzy, grab the blue wire at the cluster.
teddy_dc2
Mar 15, 2007 07:02 PM
slimjimdanny
Jan 31, 2007 07:35 PM
variable
Jan 28, 2004 12:49 PM
hmonglonertim
May 9, 2002 02:25 PM
D1ANCER
Apr 2, 2002 11:05 PM
