Ive searched,...really need help with aftermarket tach wiring
OK im installing my autometer and i need to know exactly which wire the light and power wire should run to. My friend said we should wire the power and light wires into the cruise control wires but im not sure where to run the tach light wire to, any help GREATLY appriciated thanks
Re: Ive searched,...really need help with aftermarket tach wiring (variable)
You need a 12volt power that turns on with ignition, parking light wire and a solid chassis ground. Oh, and a tach signal (usually blue at the distributor or blue single wire plug near passenger side underhood)
You need one to a power source. One to a ground on the chasis. Another wire to instrument cluster, if you want to do it the easy way, find your instrument cluster fuse in the fusebox and you can stick it in with the fuse, or else find the wire that runs to the fuse and splice it (that's what I did). Then the last one goes to your distrubuter. And, if I remember correctly, the color of the wire is the green one with and white stripe. I'll check mine in a few to make sure.
Re: Ive searched,...really need help with aftermarket tach wiring (Echelon)
That mashing wires into fuse boxes is not good. Causes arching, possible fires. What car? Ill tell you all the colors.
Ignition is black/yellow stripe at column
lights are red/black stripe at fuse box
tach is blue at distributor
ground is obvious
There ya go, boss.
ground is obvious
There ya go, boss.
allsho
04-30-2007 09:17 PM
streetspeed607
05-05-2004 06:24 AM
crx_ef8
03-10-2003 10:47 PM
90, aftermarket, box, connecting, crx, fuse, honda, market, si, tach, tachometer, tack, tech, wireing, wiring
