Suspension & Brakes Theory, alignment, spring rates....
Interesting Swap
Old Jan 31, 2009 | 12:18 PM
xXViperXx's Avatar
Default Interesting Swap
92 civic lx
00 si front and rear disc
i have the proportioning valve for the SI, the brake booster, all four knuckles, and the rear trailing arms
the knuckles swap over just fine. what about the booster and the proportioning valve? Do i need them?
Any ideas?
Old Jan 31, 2009 | 02:19 PM
jonshonda's Avatar
Community Builder
Default Re: Interesting Swap
You will def need the proportioning valve, but I don't know about the brake booster. You might need to do the master cylinder and booster together from the SI
Old Jan 31, 2009 | 04:09 PM
EFRue57's Avatar
the proportioning valve from the Si won't work. the design of it is different form your 92 civic. Just get the prop valve off an integra and it will work perfectly. It's a 40/40 as well.
Old Jan 31, 2009 | 06:13 PM
xXViperXx's Avatar
the PP from an integra, does it have to be NON ABS?
Thats what i'm hearing. Will any year teg work? 90-93? or 94-01...
Old Feb 1, 2009 | 06:46 AM
jr_deleon's Avatar
90-93 integra prop valve (easiest to find All of the lines line up but the bracket connecting it to the firewall dont all line up.), 94-up Teg RS (non-abs), 93-97 del sol (w/ rear disc), and EG Si rear disc non abs. all bracket bolts line up.
Old Feb 1, 2009 | 08:31 AM
xXViperXx's Avatar
i have a EK non abs PP valve laying around here somewhere, i'll have to check and see if that works or not. If so, i should be good to go! I'll update soon.
xXViperXx
Jan 31, 2009 07:00 PM
LSej1
Jul 8, 2008 03:23 PM
yellowjdmcrx
Jun 28, 2006 09:05 AM
FerioVtec94
Apr 9, 2004 02:50 PM
arcsec
Nov 23, 2002 11:55 PM
