4040 Prop valve
4040 Prop valve
Yeah i was wondering how and if a 4040 prop valve will line up to the brake lines where a 3030 valve was being used (did a rear disk swap on my 95 coupe). I just recieved the 4040 prop valve in the mail today and noticed there are 6 lines to go "out"...two of those are ABS correct?
Re: 4040 Prop valve (LSej1)
Two of the lines go to the master cylinder. Yes it will line up. But the bracket itself may not line up if it came out of a 92, 93 Integra or something else. You can swap the brackets, but be careful because this separates the prop valve into two pieces and a spring will fall out.
Re: 4040 Prop valve (suspendedHatch)
Thanks a bunch...I cant swap the bracket bc i dont have a bit that will fit the screws that were used in the prop valve...ill figure out how to mount it...Thanks though
BanEL
11-21-2008 04:47 PM
