squeeky clutch pedal, what was the fix?
I can't remember what the fix for this was, and OF COURSE searching comes up with nothing (damn zeroforum search function
). When I press my clutch pedal, it makes a squeek just before it gets all the way down. I noticed a bit of brake fluid leaking on the inside of the firewall, above the dead pedal, where the clutch rod goes through the firewall. Seems like I remember this had something to do with it, but I'm not sure. Any comments/suggestions?
have someone press the clutch while you listen near the slave cylinder. if the noise is coming from there, you're supposed to grease up the rod that's in there.
