opinion on skunk2 camber kit
Old Jan 29, 2009 | 07:26 PM
solsi2000's Avatar
Default opinion on skunk2 camber kit
which skunk2 camber kit should i get? im about to order one or the other.
this one?
or these without the adjustable part? (nottice the missing part)
its going to be a 30-40 dollar difference is it really worth it to have the adjustable part? thanks!
Old Jan 29, 2009 | 07:31 PM
jimmy o.'s Avatar
Default Re: opinion on skunk2 camber kit
what would be the point in buying it if you couldnt adjust it (thats what camber kits are for to correct excessive camber caused by lowering your car)
Also do you need new upper control arm bushings either way wouldnt sound like a bad idea to get the one with new bushings if that is the case
Old Jan 29, 2009 | 07:37 PM
mechanix619's Avatar
The pieces that are missing from the lower picture are not what adjusts the camber; they are simply what holds the arm to the chassis. If you can re-use your stock bolts then I would think you can get away with purchasing the arms in the bottom picture.
Old Jan 29, 2009 | 07:58 PM
94jdmeg6civic's Avatar
the ball joints suck im on my 3 set in 4 years
they made a new set call v2.o thats i heard are ok
Old Jan 29, 2009 | 08:13 PM
solsi2000's Avatar
cool thats what i figured. the description on egay says they are adjustable. and i found my answer and i cant delete this thread wtf? i dont want to start the toe vs camber discussion lol
Old Jan 29, 2009 | 10:43 PM
teamworxek9's Avatar
m on my second set, someone on here from skunk was talking to me about replacing them but we lost contact. Where did you get your repalcments?
Old Jan 29, 2009 | 10:51 PM
Devon M's Avatar
I had a pro kit for a couple years, I loved it. You need to put protectant on the rubber ball joint every few months. That is prolly why these guys are going through them so fast. Good kit, one of the nicer ones I have seen.
Old Jan 29, 2009 | 11:53 PM
solsi2000's Avatar
nice ill keep that in mind thanks
Old Jan 30, 2009 | 05:23 PM
jon4honda's Avatar
are not worth ****!!! i have them and they always move and **** never stay in the right adjustment no matter how tight u make them
Old Jan 30, 2009 | 05:26 PM
425_Booster's Avatar
I have front and rear. Havent used them yet though as my car i still under construction.
Old Jan 31, 2009 | 05:55 AM
sqsi's Avatar
I have the fronts and rears, no issues for 2 years now
Old Jan 31, 2009 | 05:58 PM
geegnokej6's Avatar
i had the pro kit too n had the rear camber kit (the rears were the sheit loved the color) they lasted years and i loved it
good kit always recommend to anyone who needs a camber kit
Old Jan 31, 2009 | 06:13 PM
EG_HEAD_H4L's Avatar
Dude for sure get the pro plus with the bushings and everything, its not worth is just to get the tuner series, you'll be much happier with the better kit. Trust.
Old Feb 6, 2009 | 09:47 AM
jhpusa
but that was a year ago i dont drive the car at all maybe 4 k a year
MansuDC2
May 7, 2006 05:01 PM
92 civic VX B18c
11
Jan 23, 2004 11:06 PM
JeremyL
Apr 12, 2003 05:25 PM
eTec
19
May 21, 2002 04:51 AM
2000si
Feb 1, 2002 04:15 PM
