-5.9 degree of camber question
HT Black Ops
I was wondering if it's ok to use the SPC adjustable upper ball joints camber kit along with, the Skunk2 upper control arm camber kit?
My camber is off really badly, I went in and got my car allined and came up with -5.9 degrees of camber.. I can't find a kit that has that much ajustment, so I was wondering if using 2 differant types of camber kits together would be safe to use?
Re: -5.9 degree of camber question (JDMCRX)
Id go with skunk2 upper thats it -3 deg is ok just make sure u get someone that knows how to align lowered hondas.
When u lower a honda when u hit bumps the camber increases thus making u car toe in faster cause it changes the angles on ur suspension.
My guy gets me to sit in my car and he toes it out slightly i can get alot more life out of my tires.
Re: -5.9 degree of camber question (SkyeC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkyeC »</TD></TR><TR><TD CLASS="quote">-5.9?!?!!? Put the springs back in your car! It's not safe to run with just shocks!
good lord... </TD></TR></TABLE>
He has Tein coil overs....Damn Jeremy, didn't think your camber was that bad, I thought my -3.5 was bad....
But yeah, most adjustment I've heard of on a kit is 3 degrees +/-
Re: -5.9 degree of camber question (EF8 ownz u)
I'm now wondering why he spent money on pimpy green suspension parts if he's trying to ruin them by having them that low? What a nerd...
HT Black Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkyeC »</TD></TR><TR><TD CLASS="quote">I'm now wondering why he spent money on pimpy green suspension parts if he's trying to ruin them by having them that low? What a nerd...</TD></TR></TABLE> LOL thanks for saying that....DICK!!!
The story behind it is, I was sold a front GSR brake conversion form my local tuner shop (SRD) from a 1991 GSR, witch we all know(atleast I do now) doesn't work on a 92-95 civic.. Well after showing them what is going on, they Replced everything with 99 GSR spindles and brakes, did the entire removal of the stuff I installed and put the new stuff on, sent my car to the allinement shop and paid me $40 for the brake pads I bought for the 90-93teg and they did all that for free... Very nice guys over there at SRDhttp://www.superiorracing.com/
Re: (CivicFerioSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicFerioSiR »</TD></TR><TR><TD CLASS="quote">this comes up a lot, do a search and you will see that your gonna hit your strut towers with your upper control arm if you put a camber kit on. (for the front)</TD></TR></TABLE>
show me where this comes up alot ..............!that a person has a -5degree + camber problem
be professional
Re: (92 civic VX B18c)
Raise your car up, it doesn't need to be that low. If you keep it that low and install a camber kit, then:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicFerioSiR »</TD></TR><TR><TD CLASS="quote">your gonna hit your strut towers with your upper control arm if you put a camber kit on. (for the front)</TD></TR></TABLE>
And your camber doesn't need to be zero either. Around -2.5 degrees is actually fine, and won't wear your tires as long as your toe is centered. Negative camber is typically a good thing for handling.
HT Black Ops
Re: -5.9 degree of camber question (92 civic VX B18c)
eTec
19
05-21-2002 04:51 AM
