ls turbo compression
Old Jan 28, 2009 | 09:35 PM
chadek86's Avatar
Default ls turbo compression
I have a ob2 ls swap in my 98 civic coupe. cylinder 4 is running 60psi and 1,2, and 3 are 150 psi across. well my issue is that the only cylinder running is cylinder 4. I know it has the shortest spark plug wire but I think its crazy that the worst one is the only one working.help please
Old Jan 28, 2009 | 09:59 PM
Unseen Racer's Avatar
Default Re: ls turbo compression
should this be in forced induction???
Old Jan 28, 2009 | 11:06 PM
n*werk's Avatar
what do you want help on?? it seem u have bad compression in number 4.. more then likely, it need a rebuild... the least compression u should have is 100 psi.. 60 is just bad.. maybe a piston melt... if u are lucky u didn't crack ur sleeve.. hope that help answer ur question..
FinedTuned
Jun 13, 2009 05:09 PM
zc89hatch
13
Dec 21, 2008 11:40 AM
89hatcher
May 29, 2006 02:41 PM
cxVtecC1
Feb 18, 2005 06:54 AM
spoonfed95
May 20, 2004 04:39 PM
