d16y8 Head On d16z6 Block
Old Jan 28, 2009 | 02:14 PM
dafirecracker's Avatar
Default d16y8 Head On d16z6 Block
Hello I heard That I would Have To Use D16z6 Head studs, Then I heard I had To Use One D16y8 Bolt Can Anyone Help Please
Old Jan 28, 2009 | 03:07 PM
Allurian's Avatar
Default Re: d16y8 Head On d16z6 Block
Why not just keep the d16z6 head and just use the y8 intake manifold? But I do believe its a combo but cant remember how many studs from each motor
Old Jan 28, 2009 | 04:23 PM
0ne-Cam's Avatar
When I swapped a z6 head onto y7 block, I bought some ARP headstuds for the y7 but ran into the same problem, 2 studs (one on far left, far right of the intake side) are different, I had to use 2 stock headstuds... hopefully that helps
Old Jan 28, 2009 | 05:45 PM
iamthefollower's Avatar
I'm pretty sure you'll have to use 1 Y8 bolt on it.. and if you do this you do know that your timing is going to be a little off right??
Old Jan 28, 2009 | 06:02 PM
gsrturbo-ek's Avatar
arp makes headstuds packages specific for the z6 y8 combos to studs are diffrent size
Old Jan 28, 2009 | 06:13 PM
that'll probably be the better thing to do is buy that arp headstud package...
Old Jan 28, 2009 | 06:18 PM
Jimster480's Avatar
lol i have a Y8block witha a Z6 head and we had the problem, with the studs not going in right (because we had all D16Y* Studs). We fixed it by forging a piece to make up for the difference so that it would torque down.
Old Jan 28, 2009 | 06:21 PM
n*werk's Avatar
one z6 head stud, that one goes near the vtec solenoid and the rest use the y8 head stud...
or is it the other way around.. hahahaa.... but that is how i did mine, either use all y8 head stud with one z6 or all z6 and one y8...
Old Jan 28, 2009 | 07:26 PM
Jimster480's Avatar
nope its all Y8 and 1 Z6.
Old Jan 28, 2009 | 08:37 PM
well it was all y8 and 1 z6 with your y8 block and z6 head.. with his it should be all z6 and 1 y8 since he is putting the y8 head on a z6 block....
Old Jan 28, 2009 | 08:39 PM
speedooo's Avatar
the y8 stud by the solenoid is different
Old Jan 28, 2009 | 09:16 PM
CivicSpoon's Avatar
9 head studs/bolts for the block you're using, and 1 head stud/bolt specific to the head you're using.
Old Jan 28, 2009 | 09:33 PM
bunnyx's Avatar
where can we find this z6 y8 arp stud combo? anyone know a good website?
Old Jan 29, 2009 | 04:21 AM
Allurian's Avatar
autozone
Old Jan 29, 2009 | 07:13 PM
Autozone?? I Can Get The Combo Kit At Autozone....If So That Would Be Nice.....Thanks Everyone 4 the Help...I'll Need Z6 Studs Cuz Of The Block A I'll need One Y8 stud far Left??
uptownfunk
Sep 27, 2008 03:21 PM
elcangripapi
11
Feb 21, 2007 12:37 PM
spun Vtec
Dec 6, 2005 01:11 PM
BigMoneyP
May 24, 2005 09:54 PM
M.A.R.C.
Jul 14, 2003 12:36 PM
