Tipps for tapping stainless steel ??? anyone
Old Jan 28, 2009 | 08:01 AM
JDMCRX's Avatar
Default Tipps for tapping stainless steel ??? anyone
Quick question what are some tipps on tapping stainless.
Im trying to tapp a M8x1.25 hole in a wastegate flange and its supper hard and i think im gonna snapp my tapp . I know stainless is hard due to its nickel content.
What are some ideas.
Old Jan 28, 2009 | 08:21 AM
weiRtech's Avatar
OG Fabricator
Default Re: Tipps for tapping stainless steel ??? anyone
use cutting oil. feed the tap in a bit, then back it out a bit, feed it in a bit more, then back out to clear the chips and so on. you also want to make sure your tap is nice and square to the hole.
Old Jan 28, 2009 | 08:32 AM
silly sohc's Avatar
Buy a HSS tapp... it will last longer and wil be less likely to snap during use.
Old Jan 28, 2009 | 08:49 AM
c jackson's Avatar
threes
if you want it done easy and right, take it to a vertical mill.
Old Jan 28, 2009 | 09:42 AM
weiRtech's Avatar
OG Fabricator
even easier, and guaranteed not to break a tap is a pneumatic tapping arm, but not everyone has access to tools like these.
Old Jan 28, 2009 | 09:46 AM
90blackcrx's Avatar
c jack has one in his bedroom.
Old Jan 28, 2009 | 09:47 AM
c jackson's Avatar
threes
and closet
Old Jan 28, 2009 | 02:46 PM
90blackcrx's Avatar
and closet
Are you out of the closet yet ?
Old Jan 28, 2009 | 05:32 PM
DESTROYER's Avatar
c jack makes manifolds with c tune.
tru story
Old Jan 28, 2009 | 05:55 PM
NMef9's Avatar
Use tapping fluid and maybe drill the hole out with a bit a few thousandths larger.
Old Jan 28, 2009 | 06:13 PM
punkinbeck's Avatar
anchor lube works excellent on stainless steels. A lot better than regular cutting oil. Keep backing the tap out as you go.. Double check your tap drill size
Old Jan 28, 2009 | 06:22 PM
srmofo's Avatar
I would completely remove the tap and clean the chips out with air or brake clean...dont forget to clean the tap off and reapply oil......Have you ever had to drill a tap out? its like dry butt seks, by the time your done you've said every bad word in the book and your *** is sore...it might be worth taking to a machine shop or fab shop
Old Jan 28, 2009 | 07:14 PM
JDMCRX's Avatar
Hey guys. I got a HSS tapp and it worked wonders . The cheap princess auto/harbour fright stuff no good LOL.
Old Jan 28, 2009 | 09:25 PM
c jackson's Avatar
threes
yes but still have the ball gag.
Old Jan 29, 2009 | 11:05 AM
legendboy's Avatar
using the correct tool for a job usually works wonders
LightningTeg
Welding / Fabrication
Apr 29, 2009 05:23 PM
Enzo Speed
Sep 20, 2006 08:47 PM
civicguy81
Mar 26, 2006 08:46 PM
boosted_zc
Jul 13, 2003 09:02 PM
R-1303
Aug 29, 2002 12:17 PM
